Old 10-16-2005, 02:35 PM
tattyann tattyann is offline
Question Electrics trouble ford escort 1.8 zetec 1997
Hi all I got a problem with my electrics, my rear lights, dipped front lights, dashboard instrument panel lights, and front fog lights sometimes do not work but when one of the above works they all do. Much appreciate any Ideas.
Old 10-16-2005, 06:56 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: Electrics trouble ford escort 1.8 zetec 1997
sounds like an electrical problem, maybe the alt.
1.8 zetec? guess you are in the UK?
Old 10-16-2005, 10:36 PM
Davescort97 Davescort97 is offline
Escort guy
Since they are all on different circuits it must be something general like a defective connection on the battery or a bad ground. Try cleaning your battery terminals both positive and negative and clean the 100 amp rated fuse in the engine compartment. Take the fuses out for the lights you are having problems with and clean the connections, then plug them back in. Remove the ground wires on the alternator bracket and sand paper the surfaces, then tighten back down. The ground is the only thing these circuits have in common so be looking for problems of this nature.
Old 10-17-2005, 04:08 AM
Thanks for your suggestions guys i will try all that and let you know the outcome. Yes from the uk Thanks again.
Checked near enough every lead and earth on the bloody car ! It turned out to be the main switch for the lights tap it on the end where you switch the lights on/off and hey presto everything works again! Its always near enough the simplist thing you would would least expect.
Old 10-18-2005, 12:33 PM
Escort guy
Glad you found it. You're right. It's usually something simple and that's what you should check first. All the best.
