Old 10-16-2005, 11:34 AM
keyway keyway is offline
Question Temperature indication low
My '96 F150 straight 6 water temperature indicates, but only about 10% of its normal range. No computer faults. The true water temperature is normal. I am wondering if this indication problem is also sending the wrong info to the computer. Thanks.
Old 10-17-2005, 05:48 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Temperature indication low
I am not 100% sure, but I think you have a separate sending unit for the gauge. If you do, there is a different sensor for the PCM that tells what the engine temp is. Look close to the thermostat area and see if there is a 2 wire sensor and a 1 wire sensor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
