Old 10-16-2005, 08:41 AM
Greenbeast96 Greenbeast96 is offline
Unhappy MY CK 1500 fails to start (sometimes)
Please help,
I have a 1996 Chevy Silverado EXT Cab 4X4 1/2 Ton Pickup. Recently my truck randomly stopped starting. I have lights, and power..I can here the starter click when I turn the key over but it fails to start or turn over. I went and jiggled the battery cables to see if they were loose and the were not, but the truck started. This happens intermidently. Now my radio is completing blacking out...Then all of a sudden it starts working again? I initially thought it was a failing starter silinoid but with the radio problems now starting, I just don't know....Who can help?
Greenbeast
Old 10-16-2005, 09:12 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: MY CK 1500 fails to start (sometimes)
try a THOUROUGH cleaning of the battery cables and terminals
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-16-2005, 11:42 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
yeah i would remove the terminals in the battery and check to see if it is corroded on the inside a very common problem and also check the cables on the alternator and any main power connections to the fuse box under hood.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 02-27-2006, 04:20 PM
oneilljb oneilljb is offline
M 98 does the same, but pulling battery cables doesnt help. I have to remove the starter then replace it. I've put 3 starters on it and a new flywheel. I've tried shimming it. The problem keeps coming back. Any thoughts?
