Old 10-16-2005, 05:06 AM
Colo900 Colo900 is offline
Send a message via AIM to Colo900
Question Why The F***?
Okay heres a question, i bought the car then like a month later i ate up the gears in the tranny so i got one from the junk yard. then i cracked the head cause of over heated and i dont know what else fixed that, then i blew the head gasket causing oil to get into where the spark plugs are at and causin smoke so thick you couldnt see behind you fixed that, then the chip in the distributor went bad fixed that, then the ground for the distrubutor or what ever went loose fixed that, motor mount broke fixed that. all this has happened in less then a year. is my problem that i like to go fast all the time? i do have a heavy foot and the engine has about 200,000 miles on it and i push it hard most of the time i drive it, and i dont plan on letting my foot go light so what should i do? i like the car and am planning on keeping it for quite some time for a hobby any ideas?
Old 10-16-2005, 05:53 AM
Canabalooza Canabalooza is offline
Re: Why The F***?
plan on spending lots and lots of money...
Old 10-16-2005, 12:21 PM
Hybrid1990crx's Avatar
Re: Why The F***?
stop kicking the shit out of your car you fucking idiot.
Old 10-16-2005, 02:08 PM
arodg25's Avatar
arodg25 arodg25 is offline
Re: Why The F***?
cars arn't designed to be pushed to the limit 100% of the time. the ones that are are called profesional race cars. and their engines get rebuilt very often.
Old 10-16-2005, 05:37 PM
DTangent DTangent is offline
Re: Re: Why The F***?
Well put.
Tien SS coilovers
Ingalls Alignment Kit
Fluidyne HalfSize Rad
AEM CAI
AEM Fuel Rail
AEM FPR
**In the works**
New Garrett T3/T04E .63 A/R
Tial 38mm Wg
Tial 50mm BOV
Fixing the shit job the body shop did to my wrecked car.
Old 10-16-2005, 07:36 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
Re: Why The F***?
take it easy on it. Its old and if its a dual point wasnt ever ment to go anywere fast.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
Old 10-16-2005, 07:40 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Why The F***?
try driving it slower, raggin the shit outa the thing is obviously gonna cause wear an tear on the thing, unless you strengthen vital components. the best way to ensure cars, especially some hondas, last is to run them in. since this isnt a new one you cant do that. but it wont benefit from being pushed hard all the time.
Seatbelts Saved My Life
Old 10-16-2005, 08:06 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Why The F***?
You're retahded.
Its like you know what's causing the car to break, you're not happy about it, but you're unwilling to change your habits?!?! Why even bother making a thread about it?!
"The nympho of info, I'm fuckin' what ya heard"
Old 10-16-2005, 08:09 PM
Re: Why The F***?
exactly what SiZ said, you know that you pushing hard is rbeaking the car, but you continue to puch it hard. and then you want to to magically stop breaking, without changing how you drive it. if you dont push it so hard it wont break. simple.
Old 10-16-2005, 09:26 PM
skotman's Avatar
skotman skotman is offline
to visualize exactly how you're putting stress on your engine, try this.
find some thread. get about 4 or 5 feet of thread.
find a largeish sized nut.
tie the thread around the nut.
swing that joker around slowly.
start swinging faster and faster and faster until you either are swinging it as hard as you can or the thread breaks.
parts in your engine, though slightly different, share something in common with this nut on a thread. they're constantly moving and changing directions whether that be in a circle or strait up and down. faster and faster movement equals more and more force at each point that the part makes a change in direction no matter how small.
over time, the metal, no matter how well lubricated or how often you change the oil, will begin to eat away at itself until something finally breaks. usually the little stuff goes first, though... belts, alternators, compressors, whatever... but just keep in mind that there is no way to repair the damage you've made without completely rebuilding and replacing everything in your engine.
you can do whatever you like to it, of course. its' your baby.
and with all the work you've had to do with it, i will assume that you're not the first owner and that the previous owner(s) also drove the car hard. it can take a little fun every once in a while, but too much of that shit and you'll be minus one engine.
Old 10-17-2005, 08:28 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
Re: Why The F***?
also increases your chances on getting tickets or crashes, cuz its not like your doin all this hard driving on the track if at all.
The Evil Sleeper
Old 10-17-2005, 02:27 PM
sblkcamaro70 sblkcamaro70 is offline
ok buddy everyone is giving you shit and what ever. You just have to understand sure hondas have a reputation of taking an abuse but...... listen these cars were built from the factory for ECONMICAL MEANS OF TRANSPORTATION. If you want to go fast and abuse it you need to up grade to components that will tak the abuse. that costs money. This car has 200,000 plus miles and if you keep abusing it you will blow the motor up right way but
but hey it isn't my car no one can tell you what to do. That was my
2 cents
peace out
Old 10-29-2005, 03:36 PM
Re: Why The F***?
thank you, ive changed my ways of driving (boring cuz im going slow ) but the bitch is lasting longer then b4, sorry i havent replyed latly thanks
