Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-16-2005, 12:38 AM
figo_madrid04 figo_madrid04 is offline
Send a message via AIM to figo_madrid04
91 z32 tt, running very poorly help please
ive got a 91 300zx tt, very well kept and runs well, however, i was driving today and i down shifted from 4th gear to 2nd at about 40 mph and i built boost, however as i was accelerating i heard a lil pop, prob a misfire. anways , i quickly came to a stop and the engine was making a rumbling niose. i let the car run for a while and at time it would make a sound like its knocking but then it would disapear. i cautiously drove the Z home, it made the same noises and had diffculty accelerating, i have a scheduled free inspection at a nissan dealership so hopefully i will figure it out, but i would greatly appreciate any help on what to expect.
I dont want the dealer to tell me that i have to replace the whole engine and ill be clueless about the situation......
i use to have a Gst eclipse, and this same problem emerged and a simple spark plug and wire and oil change fixed it up.
im new to the Z community so any help is appreciated.
thanks,
Logan
Old 10-16-2005, 12:40 AM
btw the info on the car is from the previous ride the new ride is
91" 300zx tt,
intake
ecu
custom exhust
only have had it for 3 weeks
many things to come
thanks
Old 10-16-2005, 12:57 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
could have simply had a spark plug foul on you...always think simple first.
timing belt been changed? how many miles? if you dont know if the timing belt has been changed or it has been 60k miles, do yourself and get it changed immediately. this will cause you to buy a new engine due to unfortunate valves getting hit very hardly buy solid metal pistons.
ZedEx Crew Member #4
Old 10-16-2005, 08:56 AM
talonlover's Avatar
talonlover talonlover is offline
Re: 91 z32 tt, running very poorly help please
I'm a old DSM guy too and if that happened the first thing I think of is a intake leak or a boost pressure leak(ie. hose blown loose). That doesn't explain the knocking but if you do have a boost leak then you would hear a poping noise from time to time which is the engine backfiring through the intake and would sound similiar to a knock.
1981 Delorean DMC-12 frame off resto. 2006
Old 10-21-2005, 04:01 PM
thanks for the help
thanks guys for the help sorry for the late response just finished a hard long week or exams.....
the car is in the mechanic right now, im having a friend work on it and diagnose it , ill figure it all out soon
thanks again
Old 10-26-2005, 10:24 AM
Angry An Intake Valve Is Screwed......
OH MAN, Bad news, after opening up the head, i have come to learn that an intake valve in the 2nd cylinder is messed up.......... this means that im going to have to change that valve, ....
Compression is fine so i know its not the piston and such...
however i have a couple of questions,,
while having the Head open what could be a couple of upgrades that i could do that would save me time and money, anything from manifold, to the valves, head gaskets and part in the head ect..........
any parts, jobs, websites, are all good help,
any help is appreciated , however keep in mind that i want the car to be able to pass emissions....hehe...
thanks
Old 10-26-2005, 03:54 PM
Z Cars Fanatic
Re: An Intake Valve Is Screwed......
thanks
JWT Mild Cams!
Old 10-27-2005, 07:57 PM
Exclamation head rebuild kits
any good head rebuild kits, i need to make a decision asap and i need to know what price range im looking at and exactly what components i will be replacing,
I was valves for about 500
springs about 300
retainers about 400 or soo
is it going to really cost that much or are there kits that have better deals,
btw, as of now im only looking to run the car no higher than 20 psi at any given point but right now i have a valve issue which im replacing but would prefer to do a complete head rebuild.
thanks
car is a 91 z32 tt , basic intake ecu custom exhaust upgrades
thanks again
Old 10-28-2005, 09:52 AM
pnoiSR20 pnoiSR20 is offline
Port and Polished cylinder heads might work?
Sorry i'm busy...lol
Never have sex! The virgin never dies!
Old 10-28-2005, 06:09 PM
Z Cars Fanatic
Re: head rebuild kits
springs about 300
thanks
thanks again
check out z1motorsports.com, sgpracing.com, conceptzperformance.com, and amzperformance.com
they all either work on the Z32 or sell anything and everything for them. i know Z1 motorsports sells completely rebuilt heads for $600+core.
