Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-15-2005, 10:19 PM
ctuagent117 ctuagent117 is offline
reverse gear blues
my reverse gear makes noise like (cough) "chuck chuck chuch chuck" and it gets faster and louder as rpms increase. it hink one of the teeth are chipped? should i be worried?
Old 10-17-2005, 08:49 AM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: reverse gear blues
I would have someone look at it before it gets worse, who knows your tranny might be in jeopardy.
In Progress
Old 10-17-2005, 10:41 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
if its a 93-99 than you need a new trans, its a common failure of the reverse gear or differential gear teeth break off.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 10-21-2005, 07:35 PM
well. the car runs, its just the reverse gear. will the problem spread? will i damage it more by using the gear? i seriously cant afford a new tranny right now
Old 10-22-2005, 11:47 AM
boschmann boschmann is offline
Eventually it will lose reverse totally. If you plan on having it rebuilt then fix it soon. If you plan on exchanging it for a remanufactured unit then it won't make too much difference.
Old 10-22-2005, 08:31 PM
when i bought the car about a month ago, the guy told me his mechanic said he just chipped a tooth, and that he shouldnt get it replaced because it would just be a waste of money, but i think your word means more. how long owuld it take until it completely gave out? and would it be the other gears also that will get affected or will the problem only be contained to he reverse gear? will using reverse gear less help? how much would it cost to rebuild reverse gear? i know im over whelming you with questions lol, plz help a broke 16 y.o
