Old 10-15-2005, 06:37 PM
leafsfan leafsfan is offline
intermittent rough run
98 Cavalier 2.2 stalling and poor idling.The check engine light will turn on and then it will eventually turn off. I have taken it countless times to the garage and they can never find anything wrong with it. 404 error code is stored and we have replaced/cleaned the EGR valve twice now. The car will be ok for a month or so, then the same symptoms appear. 2 mechanics have told me that if the car is not driven at highway speeds fairly often then it can form carbon deposits and foul up the egr. This car belongs to my mother and i know that it gets on the highway at least once a week. It stalls and drives rough when under 40mph or stopped at a stoplight or intersection. I guess i find it hard to believe that the small amount of city driving she does do is fouling things up so quickly. Any help with this very annoying problem is muchly appreciated.
Old 10-16-2005, 02:39 PM
Anyone?
Old 10-16-2005, 04:05 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
did you check the air and fuel filters?? maybe the plugs and plug wires as well
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-16-2005, 06:03 PM
Jake...thanx for the reply...all of the usual things such as filters, plugs,etc. have been checked. Every time this happens, the same 404 EGR code is stored. We have taken it to an independent and the dealership to get this figured out, but it is an intermittent thing that of course does not happen when i take it in. Both places have replaced the EGR and it seems ok for 2-3wks., but then the same rough running/stalling will start and stop.
Old 11-19-2007, 07:30 PM
pont1 pont1 is offline
Re: intermittent rough run
Hey before replacing your next EGR valve, at like $160-$200 a piece try cleaning out the passages to and from the valve,
Old 11-19-2007, 07:36 PM
hink123321 hink123321 is offline
Had A similar problem with a Dodge Spirit with the 2.5L engine. It never set a CEL. Turned out it was the 02 sensor. Was told that sometimes a faulty 02 sensor won't set the CEL.
