Old 10-15-2005, 01:22 PM
food4me food4me is offline
Send a message via AIM to food4me
battery crapping out
just replaced the flywheel and starter in my truck and now its having trouble turning over and the battery drains very quickly. its a 1987 dodge ram with a cadiliac 500 in it. it cranked fine before the flywheel went out.
Old 10-15-2005, 02:22 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: battery crapping out
either the alternator is shot or there's a loose connection on it.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-15-2005, 03:58 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Did you torque the flywheel right? It may have a slight bit of distortion in it whitch puts more strain on the starter. I would check for loose connections like said above before anything else though.
Old 10-16-2005, 05:59 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Lets assume your battery is good (you have had it tested, right?)
I would suggest 3 things....
1. your starter may not be shimmed properly, causing gear to gear binding. Adding a thin shim or two between the starter and the block might help.
2. Your starter armeture bearings are worn or incorrectly assembled, allowing it to drag on the inside of the starter housing..
3. Your ignition is too far advanced, either too much static timing or the distributor advance weights are stuck in the 'advanced position'.
