P0330 Knock Sensor
I have a 2000 Avalon with the check engine light on because of code P0330, knock sensor malfunction. Short of the $700 the dealer wants to replace this sensor is there anything else I can try or look into.
Re: P0330 Knock Sensor
I show 3 hrs labor and sensors are about 200$ each.
But it could be wiring or computer or a no. of things. Has the dealer checked it out or just gave you a price? For some good repair info on it The All data online DIY subcription may help. Check out the link to it below. MT-2500 http://www.alldata.com/products/diy/index.html |
Knock sensors don't usually go bad. Most common is a bad connection (loose or corroded) or a damaged wire from other car repair work. Check the wiring and connections.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
