Old 10-15-2005, 09:22 AM
cthulhu0 cthulhu0 is offline
instrument dimmer
can i bypass the instrument light dimmer?
just have the lights on bright, not dimmer controlled
Old 10-15-2005, 05:17 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: instrument dimmer
Why do you want to do this?
Old 10-15-2005, 11:04 PM
because the dimmer is burnt out, and i want to put it on an illuminated toggle instead of buying a new dimmer package that i never use.
i always have turned all the way up neways
the dimmer has a circuit board on it tho, lots of diodes, 1 transistor etc.
Old 10-15-2005, 11:19 PM
SLoe's Avatar
SLoe SLoe is offline
You should be able to bypass it. It is just a rheostat, get a multi-meter and go to work.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 10-16-2005, 01:04 PM
yeah, as soon as i hooked the switch up, it blew the tail light fuse under the hood
anybody got any ideas
93 mitsu 1.8l 4g37 just got it new at this stuff
Old 10-16-2005, 01:30 PM
ned032002's Avatar
If the switch is burned out then why don't you go to a junk yard and buy a new switch and have it turned up all the way then you won't have to worry about blowing any fuses.
Old 10-16-2005, 01:44 PM
Re: Re: instrument dimmer
just trying to save, i already have ALOT of switches laying around
if this isn't possible then i'll get a new switch
Old 10-16-2005, 06:38 PM
SLoe's Avatar
Is the power rating on the switch the same as the dimmer unit? That would cause a problem if it isn't.
Old 10-16-2005, 10:28 PM
Re: Re: Re: instrument dimmer
i don't know the rating of the dimmer, but the rating of the switch i used is 12v
is it possible that the dimmer regulates the voltage somehow?
it has at least one transistor one resistor and about 20 microdiodes all in a circuit board package
i don't have many junkyards around either
kind of a pizzer to wait for 2 wks for one to ship to me, if i could fix it myself
