Old 10-15-2005, 08:23 AM
globetrotter globetrotter is offline
Heating studio 27 p/e before bending ?
Hello
I've read somewhere that you should heat studio 27 photoetch before you bend it. I'm planning on building a Tamiya Bmw 635 with studio 27 p/e and studio 27 Jägermeister decals. Since this will be my first time working with p/e i have no clue if this is correct. The reason why you schould heat it before you bend it would be because the p/e is made of stainless steel and the p/e wouldn't bend easily not heated.In my case i should bend the p/e around the rear taillights to get the chrome surrounding around those lights.
Greetz joris
Old 10-15-2005, 08:27 AM
Vric's Avatar
Vric Vric is offline
Re: Heating studio 27 p/e before bending ?
I don't think so.
PE is metal, and metal need high temp to "soften". At this temp, you couldn't even touch it with your hand.
It's the first time I hear about that, and I really think it's unneeded.
Old 10-15-2005, 10:01 AM
360spider's Avatar
Never heard of it. It bends easily without heating.
ItalianHorses.net
Old 10-15-2005, 11:19 AM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
It's called annealing and yes it does help if you need to bend a complex part. Look here for a small how-to about the 4th or 5th paragraph. http://vodnik.net/pages/Mission/multitool.htm
Be careful as the metal will be very hot.
Old 10-17-2005, 03:43 PM
agamo's Avatar
agamo agamo is offline
Send a message via ICQ to agamo Send a message via MSN to agamo Send a message via Skype™ to agamo
Annealing PE parts is very helpful when you need to bend PE parts to complex shapes like bi-dimensional bendings, like those S27 PE screens for the engine cover of the Carrera GT, or the mesh in the front and rear fascias of the Murcielagos made by AcuStion, trying to make those bendings without annealing it's almost impossible and leads to angled bends because of the mesh screen hex pattern and the hardness and springy nature of the stainless steel
Just remember that annealing PE parts eliminates the shiny metal finish, leaving the PE part black to burnt metal color.
Parts that wont be bent to complex shapes don't need the annealing at all, parts bent to simple curves may be bent easier, but there is no real need to anneal.
When I need to anneal my PE parts, I use using a cigarette lighter, and hold the PE part with some fine pliers, put in the flame and in 2 seconds the PE parts is red, then leave the part cold to the air, take the part from other point and repeat the operation, there is no need to heat the part entirely in one step, you can do it section by section, the results are the same
Hope it helps
Happy modeling!
Ramon Garcia
Puebla, Mexico
Old 10-17-2005, 05:04 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
can't you dip the PE in boil water?
Old 10-17-2005, 11:26 PM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
No, boiling water is not hot enough. The part must get red hot then cool off.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 10-18-2005, 01:38 AM
RallyRaider's Avatar
Zomby Woof
I've hard of annealing brass, I didn’t know it worked with stainless steel too. Will have to give it a go.
Old 10-18-2005, 08:29 AM
klutz_100's Avatar
Re: Re: Heating studio 27 p/e before bending ?
me too. CAn you in fact anneal steel?
Old 10-18-2005, 08:41 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Re: Re: Heating studio 27 p/e before bending ?
Oh yes, you can certainly anneal steel. But it requires a forge!
With regards to PE, don't worry, because it's not stainless steel. The shiney silver stuff is a nickel alloy. I don't know how this alloy will anneal, but if you need complicated bends, it's worth a try. A lighter or candle will put out all the heat you need. Try annealing a bit of scrap runner from the PE set, to see what it will do. An yes, it will destroy the silver finish.
Though if my experince with S27 is any indication, this kit really doesn't need much in the way of extras....
But is this actually the Tamiya BMW 320i you're considering?
PHOTOBUCKET SUCKS
Old 10-18-2005, 10:45 AM
No it's the Tamiya BMW 635group A like this one
http://www.hlj.com/product/TAM24061
with the studio 27 p/e set like this one
http://www.hlj.com/product/S27FP2478
It's my first time with p/e and i schould bend part 19 and 20 of the p/e kit around the taillights to get the chrome trime around those.
Old 10-18-2005, 11:32 AM
lotus_man's Avatar
lotus_man lotus_man is offline
If you use a gass cooker to anneal metal you won't discolor it so much, as there is more oxegen in the flame. I use this technique all of the time for etched seat belts and the like, anything that needs a natural curve. For hard edged bends don't aneal the metal, you actually don't want it to soft.
To be honest I've never found a photo etch that can't be anealed.
My current work-
Old 10-18-2005, 11:34 AM
MPWR's Avatar
I strongly suggest that you not bother with 19 and 20. PE is a poor substitute for chrome trim. Skip 6 and 12 also. The way to do the crome trim on this kit is with Bare Metal Foil. Lots of work, but there's no other good alternative, and it will look terrific when it's done. You will almost definately be disappointed with the PE parts. And annealing them will ruin the 'chrome' finish.
If you've looked at the 635 kit, you probably know it's excellent. S27 really isn't able to improve on it. I'm opinionated about S27 PE sets, because I've been hugely disapponted by them before (read my F50 build for some details- the set for the F40 I'm building now is if anything worse ). I'll be starting a 635 myself soon, and looking at the pic on HLJ, I'd skip just about all of the S27 set. It just won't make the model any better.
PHOTOBUCKET SUCKS
Old 10-18-2005, 11:52 AM
Thanks for the info. When are you planning to make you're 635. I'll be watching it (just like with you're other awesome builds). It would be a great manual for me and i'm not gone start it directly because i'm working om a megaproject right now. I'm just planning on how to build it. And yes it's a great kit.
Old 10-18-2005, 04:49 PM
MPWR's Avatar
I'll start it in the next month or two- I'm going to try to build it for the 80's motorsport contest. I'll certainly add some detailing to it, but the kit doesn't seem to need much. As ever, you're welcome to follow it along!
PHOTOBUCKET SUCKS
