Go Back   Automotive Forums Car Chat > Cars in General
Old 10-15-2005, 09:17 AM
cadgroupllc cadgroupllc is offline
Send a message via AIM to cadgroupllc Send a message via MSN to cadgroupllc Send a message via Yahoo to cadgroupllc
Paint damage from a Magnet w/ a sticker on it.....
Hello!
My problem is paint damage related. I put a manget on the back of my JEEP Grand Cherokee. Not a problem, as I have had different magnets on it before, removing them periodically to clean, etc. The problem is that I didn't look at this magnet well. It had a clear sticker on the back of it w/ white printed text. Upon removing it the other day, I noticed that the area where the text sticker was has sort-of "clouded" the paint. I was just wondering how do you go about repairing this sort of paint damage? Or is there any way other than re-painting that area?
Thanks!
Chuck
Old 10-21-2005, 06:52 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Just take some 3M fine grit rubbing compound and apply to a cotton towel and rub on the paint. Afterwards, throw a coat of glaze and polish to bring it back to a luster.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-17-2005, 10:37 PM
lastdetail lastdetail is offline
Use a circular polisher ie,makita 9227 a wool pad. mist pad lightly with water,apply compound to pad.spead on affected area. with the polisher on the paint turn polisher on. speed setting on 2 appox 900 rpms and polish in a figure 8 until compound is almost dry. remove compound. After compounding,polishing is required to eliminate compounding haze & restore gloss.A foam pad would be for polishing. finally finish with your fav wax or sealant. wax& or sealant is applied with a dual action polisher,by hand,not with a circular polisher.randon orbiral buffers can also be used to apply wax.
