Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '88 - '92
Old 10-15-2005, 05:12 AM
luceberg luceberg is offline
Dim Headlights
Hi, I have tried upgrading the headlamp bulbs from 65watt to 95watt, but the lights are still too dim. I think perhaps the reflectors are not that reflective.
Has anyone else had this problem and can suggest a solution?
Old 10-22-2005, 12:12 PM
boschmann boschmann is offline
Re: Dim Headlights
Are the lenses cloudy?
Old 10-23-2005, 06:48 PM
Hi Boschman, thanks for the reply.
I replaced one of the lenses recently, and it now looks the same as the other one, not cloudy. The relectors look as good as they could be, but not very shiny.
They are good for up to 50mph, but at 60mph I can't see far enough ahead.
Old 10-29-2005, 08:30 PM
Re: Dim Headlights
Check between the bulb's ground & positive with a multimeter to see if you're getting over 12V with the car running. I'd suspect a bad ground.
Old 10-30-2005, 01:22 PM
Re: Dim Headlights
Thanks Boschmann,
I get 12.38 volts with the car idling. Sounds ok?
Old 11-01-2005, 10:26 AM
Re: Dim Headlights
You checked between the two headlight bulb wires? What was the battery voltage? 12.4V is a little low if the car was running. If you have an Ohmeter function check the ground wire to battery ground resistance.
Old 11-06-2005, 07:19 AM
Re: Dim Headlights
Thanks. Yes, I checked between the two headlamp wires. I did the test again today, having cleaned the battery contacts, which were a bit grimey. I got a voltage of 12.6V initially,which raised to 13.4V after a while. I checked the battery to ground and got 0 ohms, so that's ok. I am yet to discover if the brightness has improved as I am laid up at present with an arm injury. Thanks again for your assistance.
