Old 10-14-2005, 10:22 PM
aznboi_2 aznboi_2 is offline
cLutch won't go in when car is turned on
car honda civic crx hf 5spd, cable tranny, has tranny fluid, new clutch. When the car is turned offm it will go in gear. When turned on, it won't go in gear? Can not figue out whats wrong. Any help will be good.
No the car does not have a slave cylinder because its the hf model.
Old 10-14-2005, 11:16 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: cLutch won't go in when car is turned on
try start it in gear, if the car moves forward then you know it has to do with your clutch
Team Lonely Drivers
Old 10-16-2005, 12:31 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
you A) didnt line up your splines right. or B) put the clutch disk on backwords...yeah...that will do it
(just incase you didnt know...the side that "pops out" more should be facing you when you put the clutch disk on... the tranny will slide right on dont force it just wiggle and take your time...)
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 10-16-2005, 01:22 AM
Hybrid1990crx's Avatar
did it start doing this right after the clutch install? You need to go into it alittle more.
Old 10-16-2005, 03:44 AM
dagoEF's Avatar
dagoEF dagoEF is offline
That happened to me after I changed my clutch, are you sure the cable is tightened enough?? I had to tighten the cable more than I thought was necessary, but that turned out to be the problem. Something to check.
Old 10-16-2005, 05:53 AM
Re: Re: cLutch won't go in when car is turned on
wow i never thought of that. good idea!
Old 10-16-2005, 06:23 PM
thanks you guys i fixed it but the gears sound like they are grinding. Maybe i need now is a new tranny?
Old 10-17-2005, 06:13 AM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
were they grinding before the install? Did you just buy the disc or did you get the whole kit? (disc, pressure plate, throwout bearing), etc?
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-18-2005, 08:32 PM
Acrually i have no clue? the owner b4 my friend said that a new clutch was installed and they paid 900. It didnt go in gear so they solid it to my neighbor. Then thats when i took the car and got it to work. Thx to everyone on here. :} Thy nieghbor agreed to sell me the car this summer for really cheap too. So hopelly i will get it. Say something under 500.
