Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-14-2005, 07:23 PM
oldsciera86 oldsciera86 is offline
engine knocking
I have an 86 oldsmobile ciera 2.4 with 130k ; and all of a sudden my engine has started knocking/running very rough. I was using a little oil, but now smokes alot out the back. I was wondering if someone could give me a little help in what direction I need to following in fixing this problem. I thought it could be a rod or timing chain, but wasnt sure. Thanks.
Old 10-14-2005, 10:37 PM
badjoojoo badjoojoo is offline
Re: engine knocking
its probably not the timing chain...if it was the idle would be really out of wack...it might be a bent push rod...or maybe even check the lifters.
Old 10-15-2005, 05:30 PM
Re: engine knocking
I will check out the rods and lifters then. Thanks for the heads up.
Old 10-15-2005, 07:38 PM
ragrone ragrone is offline
Re: engine knocking
show me an oldsmobile that doesn't sound like a washing machine wih marbles in it and I'll show you the same one of a kind.... however, how "thick" is this smoke? I would question even the fuel being questionable with all that is going on with gasoline these days
