Go Back   Automotive Forums Car Chat > Datsun > 510
Old 10-14-2005, 06:50 PM
saga628 saga628 is offline
auto to manual conversion
Can anybody tell me how to convert a 1972 automatic 510 to manual.
things like what parts i need and how to do it
thanx alot !!!
Old 10-14-2005, 11:03 PM
dimefury's Avatar
dimefury dimefury is offline
if you are swapping for the stock 4 spd. you won't need to modify your driveshaft, some 5 spd.s will require that you shorten your driveshaft.
best way to do the conversion is to have a manual car for parts because you will need quite a bit from a donor car
the easiest way is to take the entire steering wheel support/pedal assembly out of your automatic and swap it for the manual version that has a clutch pedal
you will also need the hydrolic clutch master cylinder, the transmission, the transmission crossmember, clutch, flywheel, pressure plate, slave cylinder, basiclly every part that is on the manual that isn't on your auto
the good news is that almost everything will bolt up with no modification to your car, except for cutting out a hole for the shifter
i am willing to help you through this because i have done it before, it is really easy and very straight forward, you can do it
if you have any specific questions, feel free to ask
Old 10-15-2005, 01:35 AM
Xander_42's Avatar
Xander_42 Xander_42 is offline
Re: auto to manual conversion
The only problem now is finding a donor car with a manual. If you can't do that there are probably other cars wheree you can get most of the parts...like I'd guess 240Zs and or 210s, if yo can find 1 or both of those in a junkyard you could probably get what you. But I'n not sure I've never done that, but I was just looking at a 240Z the other day, and the clutch seemed very similar. But please, I'm not sure, don't get your jopes up on my idea.
1972 Datsun 510
2.0L 8-valve (all right!) SOHC i4
Weber 32/36 DGV carb
2" man-back exhaust
Magnaflow muffler
Lightened 240Z flywheel and 280Z clutch
Did I mention, really fresh blue paint?
That's all as of yet
