Go Back   Automotive Forums Car Chat > Cars in General
Old 10-14-2005, 05:10 PM
Johannes Johannes is offline
Banned
Neon light mounting on plastic?
There's a panel above the rear window in my 1991 Nissan Kingcab pickup that I'm going to be mounting a 12" neon on... these neons have two plastic ends on them that are a few inches long, with the tube in between. What's the best method to secure the plastic bases of the neon to the plastic panel? It's on the roof basically, so the regular double sided tape squares that come with the neon won't do it.
Contact cement? Crazy glue?
Old 10-14-2005, 06:12 PM
dantheman8328 dantheman8328 is offline
Re: Neon light mounting on plastic?
if you can remove the panel to make sure theres no wiring underneath you can use two 3/4in screws to secure the neons, thats what ive used on all my other installs and it works great. you can also tuck the wire underneath the panel so you dont have a wire hanging out.
Old 10-22-2005, 08:55 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Velcro works great. Get the industrial strength stuff at Wal-Mart. It's $5 for 5 feet. I use it on everything. It doesn't come off in the cold or heat and only takes seconds to put on or off.
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 10-23-2005, 04:16 AM
Banned
I'll check that out at Walmart, thanks.
