Old 05-20-2002, 01:16 PM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
a/f gauge
Somethign is going weird after my install of my A/F gauge.... i tapped into the wires gong into the ECU and the gauge spastically changes from lean to rich to stoic... it won't stay steady? what do you think? bad connection or bad car?
Old 05-20-2002, 02:08 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
It's supposed to do that. Only at WOT will lit be a constant. Try going out and putting the pedal to the floor and it should read rich.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 05-20-2002, 02:11 PM
89ssgti's Avatar
89ssgti 89ssgti is offline
mine does that too,it's supposed to fluctuate as the computer tries to keep the mixture stoic.
Proud member of AF's Lazy crew
Snow,snow let it snow
Af Nordic crew #008
team drift cat official member#5
Originally posted by sparq
CANADA RULES :finger:
CANADA RULES -- thats all that matters :ylsuper
Old 05-20-2002, 02:16 PM
igo4bmx's Avatar
Banned
it fluctuates so damn much i can barely tell whats going on.
Old 05-20-2002, 02:31 PM
89ssgti's Avatar
did you solder the splice?
mine goes lean at idle when cold,then goes up to like half when warmed up,but fluctuate a bit,and at full throttle it stays where it is.
Btw,I connected mine on the sensor wire,just after the connector for the O2 sensor.
Af Nordic crew #008
Old 05-20-2002, 03:08 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
the ECU program uses the "law of averages" to create a stoich reading
Old 05-20-2002, 03:28 PM
igo4bmx's Avatar
Banned
i used a tap because i was afraid of generating too much heat on that sensor with a solder.
Old 05-20-2002, 03:39 PM
89ssgti's Avatar
I unplugged mine when I solered it,tap sucks,it could be the only thing messing up your readings.I would lenghten the wire and splice it as close to the o2 sensor plug as possible(on the engine harness side).
Af Nordic crew #008
Old 05-20-2002, 03:56 PM
igo4bmx's Avatar
Banned
i spliced it like an inch from the ECU..
Old 05-20-2002, 04:02 PM
89ssgti's Avatar
I did mine in the engine bay,just before the sensor plug on the engine harness,but I guess at the ecu is good as it's the same wire
I'd still solder it though
Af Nordic crew #008
Old 05-20-2002, 06:05 PM
igo4bmx's Avatar
Banned
one thing i've noticed is that the gauge reading even moves up and down, during idle. and sometime the light just goes out... WTF
Old 05-20-2002, 06:36 PM
89ssgti's Avatar
it's normal,if you let off the gas and coast,the computer doesn't inject any gas,if you press back on the gas,the reading will show up.
also the computer monitors the ratio and change it all the time to try and stay as close as possible to stoic
Af Nordic crew #008
Old 05-20-2002, 09:03 PM
sweetcarz.com sweetcarz.com is offline
Banned
Send a message via AIM to sweetcarz.com
my friend's did that when all 4 pistons were misfiring in his Lude.
Old 05-20-2002, 11:54 PM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
*old horror movie music* DUH DUH DUHHHHHHHHHHHHHHHHHH
Installation Connection Problem: 0-Gauge to 8-Gauge, or Alternate? OnThePike Car Audio 10 12-03-2010 01:49 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 12:05 PM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 09:33 AM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 09:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 10:58 PM
