Old 10-14-2005, 04:41 PM
GringoPete's Avatar
GringoPete GringoPete is offline
Question Auto Leveling
Does Auto Leveling come with all Lesabres or only with the Limited or Grand Touring package?
Old 10-20-2005, 08:14 PM
effenfish effenfish is offline
Re: Auto Leveling
Our 1997 Custom has "Dynaride" as an option.
Old 11-05-2005, 08:14 AM
GringoPete's Avatar
Question
How do i know if my LeSabre has an automatic leveling suspension?
Old 11-05-2005, 09:23 AM
maxwedge maxwedge is offline
A990 racer
Re: Auto Leveling
Look at the struts should have an air bellows and a pump under the hood.
Old 11-05-2005, 07:40 PM
GringoPete's Avatar
Question Re: Re: Auto Leveling
Where under the hood would the pump be and what does it look like?
Old 11-05-2005, 08:46 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Re: Re: Auto Leveling
On a 98 the pump is behind the right rear wheel. It's tucked up against the frame. I had to troubleshoot it last Christmas.
Earlier cars had the pump under the hood, but I don't know when the change occured. My 93 didn't have ELC.
ELC was included in some packages of options and also available as a single option on some cars.
Old 11-05-2005, 08:49 PM
GringoPete's Avatar
Re: Re: Re: Re: Auto Leveling
Thanks......I was hoping that there would be a way for me to check without having to put the car on a lift or remove any wheels. I'll have my mechanic check when i bring it for an oil change.
Old 11-05-2005, 10:33 PM
AF -Advisor
What year
If you state the year and model you have, someone else will know where the pump is and if it wasn't even an option on a Custom for sake of example.
Old 11-06-2005, 08:14 AM
GringoPete's Avatar
Re: What year
I have a '98 LeSabre Custom
Old 11-06-2005, 08:59 AM
AF -Advisor
Two ways
I would say you have two ways to see if ELC is on the car.
Lie on the ground next to the right rear of the car. Look up under the car behind the rear wheel. If you see a pump about the size of your fist hung up next to the "frame" or if you see a link about 6 inches long between the A-arm on the right rear wheel and the link connects to the body above the axle area, you have ELC.
OR if you turn the key to on without starting the car and wait up to a minute, you'll hear the pump run for a few seconds to restore and adjust the air pressure in the rear struts. That assumes the ELC is working.
Old 11-08-2005, 07:40 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Same place for the 97.
Dan
