Old 10-14-2005, 12:40 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
This should help...
With some of my traction issues. UMI has GREAT parts, for a great price.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 10-14-2005, 12:49 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: This should help...
What is the one on the top?
Old 10-14-2005, 12:53 PM
Mr. Luos's Avatar
Firebird Guy
Driveshaft loop, connects to the torque arm to have it tunnel brace mounted instead of transmission mounted.
The stock piece is crap really. It is attached to the tail of the tranny....putting stress on the tranny under heavy load. Plus, it isn't very strong. It bends under load as well. This will really help keep the car planted in the rear.
And help me blow up the stock rear.
Stock'ish'
Old 10-14-2005, 01:02 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
lol you work for UMI? kinda seems like advertising to me... i have lower control arms, torque arm, crossmember w/ driveshaft loop and panhard rod all from spohn... they work good, but i still spin like f-ing crazy
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 10-14-2005, 01:04 PM
wrightz28's Avatar
Hmm, that's what I thought but it looked weird for some reason.
Old 10-14-2005, 01:08 PM
Mr. Luos's Avatar
Firebird Guy
Kinda advertising a little bit. The guy that runs (or help runs) UMI helped me out a ton on this purchase. Great service, great pricing, great quality.
Anyways...I have the Spohn panhard bar under my car already. Spohn has some great products as well, but tend to be a little more pricey.
Stock'ish'
Old 10-14-2005, 01:11 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
dam you are so lucky, i just put a new rearend in my caprice and that entied my pocket books for a while, cant even afford the gas to drive to school, THIS SUCKS
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-14-2005, 01:16 PM
Mr. Luos's Avatar
Firebird Guy
Many of you guys probably think I am pretty well off.
That couldn't be further from the truth. This car and related mods take all my money. I would be doing okay/well if I didn't have the Trans Am though.
On a lighter note...gas is kicking my ass too. The Grand Am doesn't seem to be getting what it should. Might be about time to let that go for a older Honda that gets 30+ in town.
Stock'ish'
Old 10-14-2005, 01:26 PM
1986Z28's Avatar
Has a Camaro
gas is fucking driving me nuts, my caprice just sits in the garage, waiting for new front ball joints, outer tie rods, a new quick ratios steering box i just bought, i just put the new rear in it, which btw is a 8.5" with a eaton posi unit and richmond 3.73 gears, which i found a the local scrapyard in a impala for 300$$$ now that i have 4 wheels disc brakes, i also have to mess around with the abs, man this sucks!!!!!!, also in the process of rebuilding a lt1 to pop into then i gotta mess around with a rebuilt tranny because of the hp im gonna make!!!
Old 10-14-2005, 01:29 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Re: Re: This should help...
Yeah, but you'd have to get the license plate frame that says "My other car has 500whp."
And the sticker that says "My POS is paid for, is yours?"
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
What does the ability to be adjusted do for these parts like the control arms? Ive seen solid ones and adjustable ones.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 10-14-2005, 01:37 PM
Mr. Luos's Avatar
Firebird Guy
These control arms are non-adjustable. The torque arm is adjustable.
You can set the pinion angle, which can allow for more bite (better weight transfer) at the track.
I didn't get adjustable control arms because the torque arm is adjustable.
Stock'ish'
Old 10-15-2005, 08:37 AM
Is that usually the best way to do it. Im looking into uping my suspension pieces and im a bit lost as to what i should get adustable and what I shouldnt....or if i should get adjustable anything.
Old 10-15-2005, 09:53 AM
Mr. Luos's Avatar
Firebird Guy
I heard that if the torque arm is adjustable, you don't need adjustable control arms.
So that is what I got.
Stock'ish'
Old 10-15-2005, 04:42 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
Re: Re: Re: This should help...
btw RedNeck, i like your sig.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
