Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 10-14-2005, 09:07 AM
wenglerl wenglerl is offline
Engine Light Comes On and Off
Well I have a 1995 Dodge avenger ES and the engine light comes on and off randomly?? It dosn't effect the way the car run. I read somewhere that there is a connector behind the left headlight the get corroded. I don't know what connector they are talking about because the the fuse panel, computers, and many other connectors are also there. Please help!!!
Old 10-14-2005, 02:25 PM
Burnerdominator Burnerdominator is offline
Send a message via MSN to Burnerdominator
Dont worry about it my Avenger does that to. But it might help if you take your gas cap off and shake it and tap it against your hand. Theres a sensor in there that gets dirty and can cause that to come on. OR if you have a code checker take that and wipe that code clear and problem solved.
1997 Dodge Dakota Sport
1995 Dodge Avenger
1980 Corolla Sr-5 (hornet creature)
Old 10-16-2005, 11:35 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Re: Engine Light Comes On and Off
If you don't have a code reader any local automotive store such as checkers, autozone, or advanced auto parts should let you use theirs.
AF COMMUNITY GUIDELINES
Old 02-05-2006, 05:12 PM
agangabissoon agangabissoon is offline
A friend of my (a mechanic) - just disconnects the battery for a bit & let the computer resets - usually does the trick, when my engine light comes on & off.
Old 02-09-2006, 08:53 PM
94StealthTT's Avatar
94StealthTT 94StealthTT is offline
Send a message via AIM to 94StealthTT
I have a service manual for Avengers. I think there is a self diagnostic you can do by turning the key: on, off, on, off, and back on. Then the check engine light will flash a message through "moors code" kind of. I can check my book also but there are two different check engine messages. One is a flashing one and the other just stays on. My book said something about it. I would just go to an auto store they usually scan for free. Disconnecting the battery is just temporary and if there is a problem the computer will detect it again, just kind of a trick on the computer to refresh it.
1994 Dodge Stealth Twin Turbo
Full exhaust, TurboXS BOV, Accel wires, High-flow cat, weight reduction, freeboost, OBX pulley, stage 3 clutch.
