Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 05-20-2002, 11:05 AM
mazen mazen is offline
Question Increasing fuel pressure
I've heard a lot about increasing fuel pressure to gain more power especially in modified engines (Direct admission,de-cat pipes...).
The ECU regulates the amount of injected fuel only indirectly by opening the injectors for a certain time. Thus the amount of fuel only depends on the existing pressure within the fuel system.So by incressing it you'll inject more fuel to the engine.
And for those that will tell you that the O2 sensor will detect a rich mixture and reduce the pulse width to the injectors, this is true.you'll not run rich at idle and part throttle BUT at full throttle (WOT) the signal from the O2 sensor is ignored ( I bet a little people know this ) so you'll get more fuel hence the gain in power.
Anyone has another view on this subject before I make the modification to my car?( I'm planning to replace my 3.0 bar FPR in my 318i with a 3.5 bar one for the six cyl engines)
Old 05-24-2002, 03:27 PM
328isRob 328isRob is offline
Send a message via AIM to 328isRob
To change the injectors or put more fuel in the car you need to reprogram the ECU... sorry to have to let you know this. It's one of the reasons why turbo's and SC's are so expensive for our cars. If more people bought them then the price would lower dramatically because of all of the money that went into R&D on reprogramming the chips to work with the larger injectors and put more fuel in the engine.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
fuel pump pressure specfications dieter LeSabre 7 07-29-2009 02:05 PM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
