Old 10-14-2005, 04:46 AM
JayR101 JayR101 is offline
Question Park Ave dies while riding down the road
Hello,
I have a 94Park Ave, 6 cyl, 3600 that has intermittly been dying while just driving down the road. Several times have had it to a shop and have thought the problem cleared up. We replaced the main computer, the cam sensor on the flywheel, the coiless distributor, and had the steering torn down, checked the fuel system and it had good pressure. There is still electric available to open open windows, run lights and the such, turns over fine, just wont start. When it dies if we leave it over night it starts okay the next day. then may run fine for a couple weeks. HELP!!! This is driving us nuts!
Old 10-15-2005, 06:53 AM
yogi_123rd yogi_123rd is offline
Re: Park Ave dies while riding down the road
Have you replaced your crank shaft position sensor?
Old 10-15-2005, 01:49 PM
Re: Re: Park Ave dies while riding down the road
Yes that was the last thing we did; but thanks!
Old 10-15-2005, 03:22 PM
maxwedge maxwedge is offline
A990 racer
Question Re: Park Ave dies while riding down the road
The basics here, when it dies do you have spark, and or fuel pressure and injector pulse? How does it restart?
Old 10-15-2005, 06:40 PM
Yes to all. My mechanics are baffled? Now they are thinking of replacing the alternator and looking for a short on the wiring of same. Starts like a champ after it sits several hours.
Old 10-15-2005, 06:42 PM
Do you know how to pull the codes off a Park Ave without the computer. On my caddy I just had to push a sequence of buttons and then count the blinks or jot numbers (memory not too good). Is it similiar? I know that they hooked it up, but just thinking something may show now.
Old 10-15-2005, 06:52 PM
A990 racer
Exclamation Re: Park Ave dies while riding down the road
Something is wrong here, either you have spark and it is weak or the injectors don't pulse, were they checked with a noid lite, was a gage actually put on the fuel rail, can't have all three and not run, assuming the engine didn't let go, which is not your case. Weak spark can sometimes fool people, looks good testing but will not fire plugs under pressure and fuel mix. When it dies does it show cranking rpms on a scanner, if not this could be an ecm problem or the icm, assuming a good cps.
Old 10-15-2005, 07:07 PM
Okay, you just went way over my head with all that, but am going to print this off and get it to my mechanic. I really appreciate the time your giving me!! Wish you lived here in Allegan MI!
Old 10-27-2005, 09:07 PM
kennycu kennycu is offline
JayR please post your results with this problem. Sounds exactly what I've been going through. I'm about to dig in and replace the crank sensor. My PA will start after a few minutes or a few hours like there was nothing ever wrong.
Old 10-28-2005, 02:23 PM
Still trying to figure it out!
Old 11-02-2005, 06:57 PM
garysr428 garysr428 is offline
Originally Posted by JayR101
Hello,
i have a 92 park ave, just got it back,was doing the same thing, they put 3 computers in it before they got a good one, runs good now, they said it is comon for a new computer to not work,some are not compatable for what ever reason, try another computer. gary
Old 12-31-2005, 09:43 PM
ohhmyyygod ohhmyyygod is offline
Angry My 88 needs some help also with this....
When my 88 PA gets to normal operating tempature, it cuts out and dies. When I try to start it, it sounds like it's flooded and won't start. But if I wait till it cools down a bit, I can drive it a bit further. Until it gets to normal operating tempature.
I don't want to start replacing things hoping for the best. A guy at AutoZone gave me this little thin key thing and told me to stick it in my computer or something next to my computer and layed me out on counting the blinks.
Where is this damn computer and were do I stick this key? (I know your thinking @**, and thank you for not typing it out).
I emailed Jay hoping he could tell me how his got fixed, but wondered if anybody here had any other input. Thank you. Daniel
