Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-14-2005, 04:38 AM
Kinsman E36 Kinsman E36 is offline
Light in dash won't go out
I have a '93 325is that has a light in the dash... a circle with dashes around each side. I figured it was my brake sensor, since my brakes needed to be replaced. I replaced them and the light is still on. What do I do? Is it even a warning light for the brakes?
Thanks---Blake
Old 10-14-2005, 05:11 AM
Dudesky_E36's Avatar
Dudesky_E36 Dudesky_E36 is offline
Send a message via AIM to Dudesky_E36
Re: Light in dash won't go out
You have to replace the brake sensors as well. They are designed to short circuit, therefore are for one time use. Once they're triggered as a result of worn brake pads and the warning light comes on, you need new ones. To avoid this in the future, inspect your brake pads regularly so you can change them before they trigger the sensors. The good news is that they only cost about $10 each. You need 2 of them- one on the left front wheel, and one on the right rear wheel. Once you replace them, the light will go out
Old 10-14-2005, 05:18 PM
venzon venzon is offline
Re: Re: Light in dash won't go out
This does not sound like a warning light for brakes. Could be indicator for high beam head lights, fog lights, or rear defogger. Let us know what it turns out.
Old 10-20-2005, 04:36 PM
LOWMONTE817's Avatar
LOWMONTE817 LOWMONTE817 is offline
Deffinately the brake pad indicator. I replaced my sensors and the light still stays on though. They say I have a short somewhere.
Old 10-20-2005, 07:50 PM
daniel 61 daniel 61 is offline
OK! Do that way- when the engine is off, turn the ignition on,to the point when all dash board lights are on , but do not start the engine. Wait 30 second, and up to 1 minute, then turn ignition off. Now start the engine, brake warning light should be reset and gone off. Good luck ! Z.
Old 10-21-2005, 03:13 PM
tennie72 tennie72 is offline
my neice has 325si Bmw but doesnt have owners manuel needs to read about what fuses are what help please
Old 10-21-2005, 03:14 PM
Old 10-22-2005, 07:51 AM
Read the sticker on the lid of the fusebox.
