Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-13-2005, 10:30 PM
Explorer94 Explorer94 is offline
94' Explorer 4X2 suspension squeeks
My 94 Explorer had been stationary for a few weeks untill today when I finaly got it to start but I noticed when I drove it, that everytime I would go over a speed bump or pull into a parking lot, it seemed to make like a squeeking noise almost like if you were to bounce on the coils of an old mattress kind of noise (that's the best that I can describe it) from the front of the vehicle. I was wondering if their was a lubricant solution I could use on the coils or any help to correct the embarasing noise.
Thank you.
Old 10-14-2005, 05:20 PM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
Re: 94' Explorer 4X2 suspension squeeks
does this happen when you are stepping on the brakes or just when it jostles up and down. If it is when you brake you may need new pads. if it is when the car bounces, most moving parts on the car are lubricated via a grease gun.
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 10-14-2005, 11:50 PM
No it's only when I go over a bump in the road or going over a parking lot enterence. I'm geussing its the coils?
Old 10-15-2005, 11:15 PM
yotermanic yotermanic is offline
Your front sway bar has two bushings held to the frame by u-brackets. I'm willing to bet you a shiny new penny that if you pulled these two bushings off the sway bar and lubed them where they contact the sway bar, the noise stops. Good luck with it.
Old 10-17-2005, 05:27 AM
You know what? Thats exacly it. But what the problem is, is when I was adding transmission fluid at night when light in the engine compartment was limited and some leaked down into the suspension parts. With a good rinse from the hose to the undercarege, I solved the problem.
Thanks
