Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-13-2005, 09:07 PM
SHUSHU SHUSHU is offline
Angry Intermittent problem
I have a '96 RAM 1500 5.2. After starting the truck, with radio on, when I turn on the turn signal, the radio turns off, turn signal won't work nor will the wipers work. After driving awhile, everything starts working again. The problem is intermittent. I have already replaced the module for turn signal, wiper and brights controller. Could the ignition switch do this? I need help! Thanks!
Old 10-18-2005, 08:18 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Intermittent problem
Try jiggling the ignition switch while the problem is occurring, see if that makes it happen or stop.
It does sound like a short or connectivity problem somewhere.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-19-2005, 07:24 PM
giddy giddy is offline
Do you know if the recall was performed on the blower motoer switch? There is a recall on it and the symptoms you are describing are listed on the recall notice. You can check for unperformed recalls at dodges web site WWW.dodge.com using the last 10 digits of your vin code. Hope this helps.
