Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 10-13-2005, 07:28 PM
skybob7777777 skybob7777777 is offline
Anyone ever done a 3.4 swap???
I did a serch on this with not many results. I found a good deal on a low miles 99 3.4L tacoma motor/trans/tcase. I want to put it in my 91 v6 5speed pu. Truck has good motor trans., tcase in it. Can I use my trans, tcase? Anyone done this swap? or knows where to find info on it/ Thanks in advance
Old 10-17-2005, 11:17 AM
GDBSKE GDBSKE is offline
depends if you have the 3.0L or the 2.4L. If your truck is the 4cyl, the swap is a huge job. If it is the six cylinder, it is not that bad. You need the ecm and wiring harness. Mostly a bolt in, but I think you need the t-100 oil pan because of the differential. Look on 4x4wire.com they have a write up on it.
