Old 10-13-2005, 08:23 PM
baker1234 baker1234 is offline
Thumbs down engine blown great!!!!!!!!!!
so my last post was about how i was on the highway and i lost power to my car i pressed on the gas and the rpms nor the speed would move i started to pull over and my car shut off as i was decelerating, my mecahinic has had it for a week and he could only take a "peek" at it and he says it looks to him like my t-belt jumped a tooth or so, now is this possible like is that how it happens i figured the timing belt would have fallin off or somthing i say its there any damagee to my motor and he says idk ill find out when i start ripping it appart, now i say are you sure its not the fuel pump of colleged injector or fuel related the way it cut out he says not by the sound of it who can help as to whats goin on i dont have the money right now to rebuild my motor i just had a new motor put in with 35,000 miles less than a yr ago please help any ideas or suggestions whould be greatly appreciated
1997 gst (5speed)
Apexi 3" turboback
k&n intake w/hardpipe
greddy type s bov w/ piping
Apexi SAFC2
new revised 3g lifters
magnacore 10.3mm wires w/ new plugs
Old 10-13-2005, 09:07 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
With that engine rebuild you replaced the timing belt right? Because if so I bet the belt slipping would only be 40% likely. When you press the gas without being in gear do you hear the engine rev at all? Also do you hear any new, weird sounds comming from the engine or exhaust? And lastly...clutch replacement. Have you replaced the clutch recently? You sure the clutch isn't slipping and needs to be replaced? Just know that what the mechanic says isn't always right...
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 10-13-2005, 10:15 PM
Black97GST Black97GST is offline
Re: engine blown great!!!!!!!!!!
if your timing belt slipped or broke, you would most likely know it lol. our engines are interference engines so the valves would smash into the top of the pistons and make a loud noise and the car would just die. A timing belt doesnt USUALLY snap in half, the teeth on it usually get worn and break off causing the belt to slip and mess everything up. what your describing sounds like a possible t-belt but hopefully not! Good luck!
Old 10-14-2005, 08:31 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Why don't you do a compression test and then a leak down test if necessary. You can do a compression test yourself for about $20.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
