2003 ignition harness
im looking for a diagram of the ignition harness for a 2003 altima.....i need to find the accessory 12v wire.....thanks
Re: 2003 ignition harness
I found a digital picture of the actual harness connector. I can't post an attatchment. I will try to PM it.
12volts green + ignition harness Starter black/red + ignition harness Second Starter black/yellow + ignition harness Ignition black/red + ignition harness Second Ignition N/A Third Ignition N/A Accessory red + ignition harness Second Accessory white/blue + ignition harness Keysense red/blue to black/red + ignition harness Power Lock pink - pin 37 @ BCM by fuse box Power Unlock brown - pin 44 @ BCM by fuse box Lock Motor yellow/red 5wi pin 30 @ BCM by fuse box Unlock Motor green/white 5wi pin 23 @ BCM by fuse box Parking Lights+ red/blue + driver kick panel Parking Lights- N/A Hazards green/red - pin 61 @ BCM by fuse box Turn Signal(L) green/black + pin 22 @ BCM by fuse box Turn Signal(R) green/yellow + pin 21 @ BCM by fuse box Reverse Light green/white + driver kick panel Door Trigger see notes - BCM to right of fuse box Dome Supervision comes on with unlock Trunk/Hatch Pin purple/white - pin 18 @ BCM by fuse box Hood Pin yellow/black - hood pin switch Trunk/Hatch Release red/black or blue/red - pin 76 @ BCM by fuse box Power Sliding Door N/A Factory Alarm Arm pink/blue - driver switch in door Factory Alarm Disarm white/blue - driver switch in door Disarm No Unlock Tachometer white/green ac ECM behind glove box Wait to start N/A Brake Wire red/green + brake pedal switch Parking Brake green - parking brake switch Horn Trigger green/white - steering column Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Modules MAKE : NISSAN | MODEL : ALTIMA | YEAR : 2003 * The logo is registered trade mark of Nissan Corporate. Copyright © 2000-2001 Directed Electronics, Inc. All Rights Reserved. Revised: 11 January 2001 This website is for the sole use of authorized DEI personel and it's participating installers and retailers. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. |
