Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-13-2005, 05:37 PM
Jmart1103 Jmart1103 is offline
Power Steering Switch
Hello to everyone, I have a 99 Intrepid with a 3.5 engine from a 00 intrepid R/T,( i had the 2.7 engine failure at 50K miles), so everything is working good with the new engine, except that the check engine light is on and the code is p0551 (power steering switch failure) i tought it was going to be an easy task replacing it, but turns out the dealer says they dont list the part, and that it is located on the rack & pinion, but i checked the rack & pinion and there are no electrical connections on it, does anyone knows where exactly the switch is located? or if you had the same problem and got it fixed, how much did it cost? i would appreciate any advice or orientation. Thank You .
Old 10-13-2005, 09:47 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Power Steering Switch
usually the power steering switch is located behind the pump on the pressure line of the pump. If it's not there, then look all the way down the pressure line going to the rack & pinion and you should see a sensor mounted in the line.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
