Old 10-13-2005, 04:21 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Kick panel enclosures
Are kick panel enclosures all they're cracked up to be as far as improved staging, etc? I'm looking at some component setups, and most people have recommended kick panel enclosures over putting the woofer in the door, and the tweeter higher up...with that in mind, is Q Logic the only company that sells preformed kick panels, or would I be better off making a pair myself? (I have no fiberglass experience, but would love the oppertunity to learn if it's within reason as far as skill needed goes...)
Sorry for all the questions, and thanks in advance.
-Chuck
Old 10-13-2005, 06:07 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
wow .. an actual SQ question, better jump on this one
in a word, yes ... kickpanel mounting minimizes pathlength difference better than any other mounting except in some cars (like the chrysler cab forward designs) in which mounting them in the dash as far forward as possible is actually better.
For midbass frequencies - the ONLY thing that matters in creating a phantom center image is pathlength difference, so door mounting is a poor option.
For midrange frequencies - it relies on pathlength differences AND intensity, so you need to angle the drivers for best effect. Generally you point the midrange at the rearview mirror and work from there.
For high frequencies - it relies almost entirely on intensity. You have two options for the tweeters (or maybe 3). The first (and generally the best) is to mount the tweeters as close to the mids as possible and in front - the mids should be in the back so they are farthest away. The second is to mount them on/in the dash as far to the front and to the sides as possible (i.e. right next to the A-pillars). Point the tweeter at the windshield, mount them so that the driver or passenger cannot see ANY of the front of the tweeter directly. The third is to do 1 & 2 together, but de sure to crossover the dash tweeter high, like 8-10Khz. If you choose method one and your stage image seems low, let me know and I will tell you how to fix that.
If you buy the qlogic, make sure you stiffen it up by putting dynamat, fiberglass or both on the inside before you install it. If you don't, they will most likely resonate.
Old 10-14-2005, 04:23 PM
Re: Kick panel enclosures
Thank you very much for that answer...very comprehensive. I was under the impression that the tweeters should be pointed straight at the listener, but I guess not. Would mounting the tweeters in the kick panels not be worth it then, since they would be pointing at the driver? If I'm understanding this right, that would be good to mount them there, so long as they're mounted by the woofers in kick panel, but this configuration would also point the tweeters at the driver, which isn't desirable(?) Thanks a lot for all your help!
-Chuck
Old 10-15-2005, 11:58 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
Re: Re: Kick panel enclosures
It depends on the tweeters. Sometimes it's better to have it directy at the listener, sometimes it may not. Reason you can mount the tweeters (conventional dome tweeters) off axis because the sound waves are distributed in a uniform pattern. Metal type tweeters are more forgiving when it comes to mounting off-axis. Of course, there are exceptions.
If the tweeters are not made to be pointed directly at the listener, and you happen to point it to the listener, it can sound unnatural and perhaps even fatiguing.
I love them sub wufers
Old 10-16-2005, 11:29 AM
Ok, thanks for that. On a similar kick panel question...is it best for the midrange speakers/woofers to be aimed at the driver's head, or the area between the passanger and driver? Sorry for all the questions, but the answers are very helpful.
-Chuck
Old 10-16-2005, 01:44 PM
Audio Guy
I answered that on the midrange freq section ..... you aim the mids at the dome light where rear view mirror is. They almost always sound better when neither of them is pointing directly at you. Once you get everything done, you might find that reversing polarity on the passenger side midrange speaker will help your imaging a little, you have to experiment. If you use tweeter mounting option 2 (mounting them up high) it may sound better if both mids are wired out of phase.
Old 10-16-2005, 08:44 PM
Ok...I think I've decided to try my hand at making my own enclosures both to save money, and just because I want to try something new. I really appreciate your helping me figure out how to aim the speakers...I'll try and get some pictures up when I finish them, though it'll probably be a few weeks...damn school
-Chuck
Old 10-17-2005, 12:21 AM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
i think paul explained pretty well
as far as fiberglassing goes, i didn't know how to fiberglass, and i picked up it really easily. You won't be making q logic type kicks unless you're already good at that stuff, but if you want to start, it will just take some time. I give it 1 week, 2 at the most for your kicks to go from start to finish (for a beginner)
http://web.njit.edu/~cas1383/proj/main/
^there's a link to get you started
Old 10-18-2005, 03:23 PM
AndonD454's Avatar
AndonD454 AndonD454 is offline
Send a message via AIM to AndonD454
paul.. im confused abotu your 1st post.. youre sayin that tweeters should be closest to you and mids should be behind the them??? and angled from the dash to fire right at the rierview? what? as in the mids should be way up in the dash by the windshield and the tweets should be as close to you as possible on the dash but pointing at the windshield? im so confused.
if this is the case why would you recommend kick panels? usually with premade ones the kicks are in the corner of your floorboards facing right at you with the tweets facing you too mounted right on top of the mids.
can you simplify a little?
why do the mids and tweeters need to be as close as possible? why is the door a bad spot for the mids?
1996 Explorer 4.0 V6 4x4
Sold all my shit.
waiting for more money
Old 10-18-2005, 04:47 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
The mids and tweets should be as close to each other to eliminate pathlength differences and reduce separation (where you can tell that the tweet is high and the mid is low even when you close your eyes). These are pretty normal problems when you're using passives and you separate the mids and the tweets, if you go active and play with the time correction, cutoff frequency and cutoff slopes you can greatly help, if not completely eliminate both of them even if you have quite a bit of room between the mids and tweets.
The door is a fine spot for midbasses, but it's bad for midranges because they're pointed right at each other. You're almost 90 degrees off axis from the driver's side mid, and maybe 40 degrees off axis from the passenger side mid. The resulting frequency response from each side will be very different, off axis angle plays a big part in frequency response for higher frequency drivers.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-18-2005, 05:08 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
i dont understand how to build sealed kicks
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 10-18-2005, 05:21 PM
GSteg's Avatar
my buddy has his mids in doors while his tweeters on the a-pillar all the way in the corner. It sounds beautiful with no hints of separation.
I also prefer shallow slope (particularly 1st and 2nd order) when it comes to xover. It sounds more natural to me and blends in better. When I switch to 4th order, it sounds separated and artificial.
Here is my setup:
HP midbass- 63hz @ 12db
LP midbass- 300hz @ 6db
HP midrange- 600hz @ 6db
LP midrange- 1400hz @ 18db
HP tweeter- 2200hz @ 12db
Old 10-18-2005, 07:00 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
i thought you had horns...looser
Old 10-18-2005, 07:29 PM
Mannyb18b's Avatar
Hey gsteg, does your buddy have the passenger side mid out of phase?
Alpine H/U-
CDT EF-61's
NSB-100
Old 10-18-2005, 10:10 PM
GSteg's Avatar
Sold them. I'm using ribbon tweeters now
