Old 10-13-2005, 03:52 PM
escort_jay102 escort_jay102 is offline
Gas Mileage Drop!
I have a 93' escort, I been seeing a recent decline in mileage. I drive city/highway every week. I was getting around 31mpg, but now I am getting 26. I am not speeding up too fast, or braking too fast, I drive normal. It's not even cold weather out yet(michigan resident) and I don't use the heat. What could be my problem? Do I need to tune-up my car? I tuned it up last feb, i believe. Please someone help me, i getting a little frustrated.
1998 Chevy Cavalier
2.2/ K&N/ Ractive muffler
1994 Chevy s10
thrush welded muffler
Old 10-13-2005, 06:36 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Gas Mileage Drop!
Try using a fuel system cleaner such as lucas fuel system cleaner (which I have used and found helpful) Also change your oil check tire pressure. If you like to tinker check the condition of you plugs maybe clean them up (watch you dont take the platnum off) pcv valve could need replacement and finally you said you tuned it up last feb but what did you do and what did you use? Let us know if these tips hellp
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 10-13-2005, 06:56 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
How old is the 02 sensor? I've heard that will drop mileage.
Nevada Tumbleweed
Old 10-13-2005, 07:06 PM
All i did was replace the spark plugs and the wires, and the paper air filter into a K&N. The car has only got 75,000 miles on it, so maybe the 02 needs to be changed, and the PCV valve too. I just recently changed the oil and my tire pressure should be fine, but i'll check out the PCV valve and the 02 sensor.. Is there anything else I could do?
1998 Chevy Cavalier
1994 Chevy s10
