Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 10-13-2005, 02:43 PM
booblinker booblinker is offline
Send a message via AIM to booblinker Send a message via MSN to booblinker
Lebaron Questions
I am picking up an 89 lebaron gtc. It is a convert., 5 spd, 16" wheels, 4 wheel disc, leather seats etc. My question is: I am not sure if it is a 2.2 or 2.5, i've read that the 2.5 gtc only came in auto. Is this true, or could it have a 2.5 turbo spd. I'm hoping its the 2.2 TII.
thanx,
brandon
Old 10-26-2005, 01:58 AM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
well, the 2.5 is the 2.2 stroked so the bell housing is the same. If you look under the hood there will be a sticker that tells the engine size.
Old 10-26-2005, 11:00 PM
livinginh's Avatar
livinginh livinginh is offline
Send a message via MSN to livinginh Send a message via Yahoo to livinginh
Re: Re: Lebaron Questions
Originally Posted by rrudyii
my 1993 Chrs. Labron has no power at all. What's the matter with it?
How about starting your own post for this instead of hijacking this one.
Old 10-29-2005, 07:00 AM
pooky pooky is offline
thanx,
brandon
It should be the TII w/ an A-555.
Old 11-03-2005, 05:03 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
In 1989 the Turbo I could be had with the A-413 automatic or the A-520 five-speed manual. So just because it is a five-speed doesn't mean it is a Turbo II. There are a lot of ways you can tell a Turbo I from a Turbo II. The Turbo I has a silver valve cover and intake manifold while the Turbo II has a black valve cover and intake manifold. The Turbo II did only come with a five-speed but it was the Getrag forged A-555. If you can get a look at the side of the transmission A-555 should be stamped on the side if it is a Turbo II. The easiest way to tell is to see if the car has an intercooler or not. It will have a pipe going to it from the intake. It will be on top of the radiator next to the overflow and it will look like a small radiator itself.
If you still can't figure out if it is a Turbo II or not just post a picture of the engine bay and I'll be able to tell you.
