Old 10-13-2005, 02:20 PM
stardustnelson112 stardustnelson112 is offline
Unhappy 1995 blazer emmission control?
I just bought a 1995 chevy blazer 4.3 vortech 4door 4wheel drive,3 DAYS AGO.
well i took it and had a code ran on it and it came up as aux emmission control. ???
Does anyone know what that is?
The cheack engine light came on and went back off.
And it is missing during idel sometimes its fine and sometimes its not.
and you can smell the fuel burning rich.And have very low gas mileage
PLEASE CAN ANYONE HELP.PLEASE
Old 10-13-2005, 02:43 PM
jsgold jsgold is offline
Unsure of your code, might advise the code number, but... The poor gas mileage and smell are possible indicators of CPI failure. A lot of information on here if you search. The fuel pressure regulator and injectors sit under your intake plenum. The regulators are prone to leaks which will cause anything from missing to locked up engines due to cylinders being full of gas. You can remove the round sensor under your vortec plate and look inside the plenum for bright shiny areas. The entire area inside should be dark. May have to rmove the entire plenum to be sure(I am going to be doing this to my 93 in about 4 days), but that is best place to start. Other problems with these, EGR valves with carbon on them, vacuum leaks, dirty idle air controls. Plenty of information here, use search and check out the "important" topics listed above.
I used to be indecisive, now I am not so sure.
Old 10-13-2005, 03:01 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: 1995 blazer emmission control?
try removing and cleaning your EGR valve.
Old 10-15-2005, 07:49 PM
What is a cpi?
Old 10-15-2005, 08:20 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: 1995 blazer emmission control?
Originally Posted by stardustnelson112
What is a cpi?
First of all , what code number was it.
They have to supply the number.
I looked up all the codes and don't see a code for that fault.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-16-2005, 06:29 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
What is a cpi?
Central Port Injection... Basically it's your fuel injector. What happenes is that the regulator starts to leak and dump gas. This can cause a rich fuel condition and send your emissions controls and output off the chart.
Pull your upper plenum, check for washing (where one side is cleaner than the other) If your passenger side is washed, it's your CPI, if the driver's side is washed, it's your nut kit.
Should either of those be the case, replace them, then do an oil change to get any gasoline out of your oil.
Old 10-16-2005, 07:35 AM
blazee's Avatar
blazee blazee is offline
Problem?
What is a cpi?
There's some info about it here: (basically the long version of what rlith just said)
http://www.automotiveforums.com/vbul...d.php?t=462726
