Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-13-2005, 01:07 PM
1995FordContour 1995FordContour is offline
more probs (please help)
i have a 1995 ford contour gl 2.5 liter v6 24 valve engine
my radiator is cracked and i am going to repair that monday but before then it was the water pump i had replaced with the metal empellar on it
my mother had put too much oil in my car while she had it when i was away and drove it around like that for about 2 weeks
but here is the problem when i drive around for awhile or pick up the speed to about 45, after that when i stop the car it starts to shake and the check engine light comes on and a knocking noise begans to sound off from the engine and the more i drive it like that like on my way home it will get louder and sometimes even cut off
could anyone tell me what they think the problem may be and how severe and expensive it could be
Old 10-13-2005, 01:41 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
spun rod bearing is my guess as before.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-13-2005, 02:25 PM
mah bad i must have skipped that but whas that and would i need to take apart my engine?
Old 10-13-2005, 02:35 PM
i think u r exactly right sir
oh gosh now im going to have to take apart my engine
i worked on my dads 1996 nissan altimaand replaed a gasket in his engine but the contour is a headache
Old 10-13-2005, 02:53 PM
the rod bearing is the bearing that connects the rod to the piston. The engine will need to be fully torn down. Either that, or swap in a 3.0L like most people do.
"The CEG Nazi"
www.contour.org
