Old 10-13-2005, 11:54 AM
brat_grl brat_grl is offline
She just wont start
Ok guys, dont know what to do, 92, lumina, 3.1. have always had problems starting, when i turned the key, it would click then nothing, but when i turned the key again, she would start up and go. no problems running at all, then last week. I ran to the store, no problems, came back home to drop off the milk and leave again, and from then on she wont start at all, ? starter? ignition? selinoid?
Old 10-13-2005, 12:30 PM
jdl jdl is offline
Re: She just wont start
Are you saying it won't crank, nothing? Is your battery fully charged? Have you tried using jumper cables on it? If this is an automatic, have you tied starting in neutral? Leave the dome lite on, turn the key to crank, how does the lite react? If it dims badly or goes out, I would check the battery and cables. You could run voltage to the starter field terminal to see if the starter would spin, but we're getting ahead of ourselves. If you try something like that, make sure the tranny is in park or neutral and the e-brake is set.
Old 10-13-2005, 01:29 PM
battery is brand new, everything works, windows, lights, door locks, radio, everything, just wont start, no turn over, no click no nothing
Old 10-13-2005, 03:39 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I bet you have a bad starter. When they first start to go bad, they will intermittently not start, usually after the engine is warm and you shut it off for a short time then try to re-start. Eventually , it won't start at all.
Old 10-14-2005, 06:41 AM
meuhus meuhus is offline
i'd say starter too
Old 10-23-2005, 12:32 AM
kindnessndrage kindnessndrage is offline
Send a message via AIM to kindnessndrage
Thumbs up
Good to know... I have a 91 lumina and I'm having the same problem... I figured it was the starter... Dad figured it was the starter... From the looks of it it's my starter. Hoping this will be the end of my troubles for awhile
