Old 10-13-2005, 11:49 AM
vinnym86's Avatar
vinnym86 vinnym86 is offline
Send a message via AIM to vinnym86
What mono-amp?
OK, i have 2 eclipse 12"s that give 250w rms at 4ohms.
Whats a mono-amp that I can use that will be able to handle 2 4ohm subs, and is affordable? ($100-$200)?
I've looked at profile, but the manual says that the mono amp must see a 4ohm load or higher. if i have 2 4ohm loads, that would make the amp see a 2ohm load, right? or 8ohms? (i'm really confused)
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
Old 10-13-2005, 05:39 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: What mono-amp?
if you wire the subs in parallel, + to + and - to -, then the load impedence will be 2 ohms, and your profile wont be able to handle it. But if you wire the subs in series, + of one sub to - of the other and then - of one sub to - on amp and + of the other sub to + on the amp. This will give you an 8 ohm load, and your amp can handle it.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-13-2005, 10:50 PM
vinnym86's Avatar
Re: Re: What mono-amp?
wouldn't that mean I'd be drawing less power from the amp?
Old 10-13-2005, 11:24 PM
tblake's Avatar
In God We Trust
Re: What mono-amp?
um, I dont know what you really mean. more current will flow with less resistance. You will have more power I guess with the 2 ohm load, but your amp will not be able to handle that much current without overheating. what I say to do instead of getting a mono amp and wiring in an 8 ohm lead, get a 2 channel amp and hook each 4 ohm sub up to each channel. that way you will have the maximum amount of current flowing that your amp can handle.
