Old 10-13-2005, 09:36 AM
agustincorrea agustincorrea is offline
Transmision shifting hard on a 2004 TB
Folks, I have a 2004 Trailblazer which sometimes shifts hard and on reverse will go neutral also. this happens every other week. The fluid looks red and clean and its at the right level. The dealer checked the Trany but found nothing rare. I have already 30,000 miles on it. Have only use my Hitch for my Mountain bike.
DOes this mean that the Transmission is starting to go bad?
Old 10-13-2005, 11:05 AM
dach95 dach95 is offline
Re: Transmision shifting hard on a 2004 TB
Do you have extended warranty...if not I would worry the dealer now and immediately. Keep all documentation of your issue, and be explicit to the problem. They always check to record and sometimes, you can get away with them not fixing the issue the first time even if the warranty runs out.
Have them check to see if there is any flash update for your issue. Each update I got seems to do miracles for me...
2002 Chevy TrailBlazer 4X4 LTZ EXT Summit White
4.2L I6, 3.73 rear diff ratio K&N HighFlow KN-1009 air filter Airaid Throttle Body Spacer Sylvania Silverstar Lows 9006ST
Infinity Burl Wood molded dash kit In-Channel VentShades 35% front windows.
Excellent source of info http://www.trailvoy.com
