Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-13-2005, 08:57 AM
brelley brelley is offline
possible starter problem
Got into car a couple hours after going to the store and the car would not start. Had plenty of power, everything electric work, but no noise when the key turns.
Should I replace the starter? Would the starter just go out like that or are we overlooking something simple? Many Thanks in advance.
Old 10-15-2005, 07:09 PM
fordin K fordin K is offline
Re: possible starter problem
is the gear selector all the way in park (auto) ?? does lights flicker at all ?? no clicks, or sounds. how about fuel pump hum or dash lights when turning on key do they work like normal.
Old 11-04-2005, 03:31 PM
Re: Re: possible starter problem
Gear selector is in. Tried jiggling it and that did not work. Lights do not flicker but I don't have a volt meter. Clicks somethime then stopped but not even close to everytime I tried. Can hear the fuel pump and dash boards lights seem fine.
11/3 - Changed the starter and no luck(expensive mistake). Is there some sort of fuel cut off switch some where? Or is their a way I can check the ignition switch without taking it to the shop?
Regards,
Brelley
Old 11-05-2005, 11:59 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
did you check the timing belt? what year engine?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
