2001 Sunfire check engine light on
Hello,
Last night I put some feul injection cleaner in and drove 20 km. The tank was not quite half full. So I only put half in. Drove about 15km this morning and now the check engine light is on. Will check it after work. I check the cap and it is tight. Any ideas ??, Should I be worried?? Homerr PS: I will keep you informed as what happens. Also I noticed from time-to-time my TC light comes on then goes out (not related, I know that much). |
Re: 2001 Sunfire check engine light on
make sure the gas cap in tight.
I did that as it is in my post.
Didn't see it, ok now get it scanned and post back the codes.
Solved ! !!
When we were out delivering flyers, the car starting to hesitate and the RPMs would go down then back to normal. So I decide to go back home to see what was going on. On the way back home I could hear a ‘snapping’ sound under the hood. When I go back home, there was a blue spark coming out from the second spark plug wire on the module. I took it off and the contact on the module was totally rusted. I have never seen anything like that before. It took me over a half hour with sand paper to clean it off. Cleaned inside the spark plug wire as well and started the engine and all is fine and the light went out. homerr |
Get some dielectric grease and use it on the coil connections ans wire/stud connections.
It started 'snapping' again. Put my hand about 1 inch by the module/coil packs and got lifted. Drank two beers. Then replaced spark plug wires with proper grease on the connections and all is perfect (for now).
Homerr |
Re: Re: 2001 Sunfire check engine light on
You need to replace the coil as well as the wires.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Thanks GMMerlin for your reply. If something else happens then I will know to check the coil pack.
Homerr |
