My Modded Neon
I have a 2000 sohc neon, "modded", cold air intake, obx headers, fuel regulator, IAT chip, cool shoot kit, short shifter, Bilge Blower ( on intake), & accel 30 lb injectors. I still have a problem beating a GS-R, my 0-60 is well in between 7-8 sec. Is something slowing me down, or just need more modds. Im about to put an underdrive pulley, & cam gear. Hope that will do it, I also heard that you can get more power out of a sohc, dont know about that, cause dohc seem to blow up easier, because of higher rpm range. Well anybody out their help me out with some info.
In advance, Thanks. |
Re: My Modded Neon
1)CAI 2)Header 3)Exhaust 4)UDP 5)Cam After that you start looking at stiffer motor mounts, maybe an MSD ignition, then if you want to get really wild you go with pistons, rods, and other stuff. |
Re: My Modded Neon
From the sounds of your mods, I would think you have potential of being slower than stock. The only thing I would keep would be the header (maybe) and start over with high quality proven mods. Lose the 17" wheels in a hurry.
Re: My Modded Neon
My CAI is an Injen, I have purchased an AEM cam gear, also a cosmo racing UDP, I heard that stock exhaust is ok for thecar, sometimes even better.
Re: My Modded Neon
My CAI is an Injen, I have purchased an AEM cam gear, also a cosmo racing UDP, & I heard that stock exhaust is ok for the car, sometimes even better.
Re: My Modded Neon
My CAI is an Injen, I have purchased an AEM cam gear, also a cosmo racing UDP, & I heard that stock exhaust is ok for the car, sometimes even better. Also, neon rt, how did you know ia had 17" wheels, I didnt even mention those, via the way my car is also slamed.
Re: Re: My Modded Neon
Re: My Modded Neon
So when I get the AEm cam gear on, & the UDP, will also be true HP.
http://sportcompactcarweb.com/inside...technology01a/ The UDP doesn't add HP, but rather frees up HP. It will turn your accesories slower therefore allowing more power elsewhere. It is also lighter which means the engine doesn't require as much power to turn it. |
