Old 10-12-2005, 10:59 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Sulfur smell
Ok, so when I stop and shut off my car I can sometimes smell sulfur. I have noticed it more lately especially when I get home. I thought I read like a week ago that its from a clogged cat, but I have a 2001. Could the cat really be clogged already? What else could do that? Thanks!
EDIT: Shit, this isnt the Cavalier forum! Damn am I confused (its been a long ass day). Its a 2001 Cavalier with a little over 30k miles and it smells like sulfur, but I only notice it when I stop. Any ideas?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-12-2005, 11:02 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Only weird smells I can think of are rich exhaust, the smell of the grease from the cv axle, and the smell of frying clutch.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 10-12-2005, 11:18 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: Sulfur smell
I actually had that problem all the time... But then I cut down on the bean borritos from Taco Bell. I bet you're running rich.
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 10-13-2005, 05:03 AM
macder macder is offline
Send a message via MSN to macder
Re: Sulfur smell
Aside from what's already been said, maybe there is oil leaking onto to the exhaust causing it to burn. The smell of burning oil is definetly not a pleasant one.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 10-13-2005, 07:11 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Sulfur smell
Things to try:
Switch brands of gas.
Check O2 sensor voltage at both cruise/idle and WOT
Replace cat.
Drink a beer.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-13-2005, 09:06 AM
Kuhn's Avatar
Re: Re: Sulfur smell
Originally Posted by spyderturbo007
Things to try:
Replace cat.
Drink a beer.
The beer is crucial!
'98 Eclipse RS
Old 10-13-2005, 09:38 AM
Carolina Z Carolina Z is offline
Re: Sulfur smell
Its the catalitic converter, replace it or if you are lucky and dont have a state veh insp, like here in SC , get rid of it, most are pretty easy to remove and any exhaust shop can then weld in a piece of pipe to connect the front to the back of the exhaust system.
Old 10-13-2005, 09:45 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Sulfur smell
Actually you're lucky, i have access to TSB's from GM because of my job, i'm gonna check and see if there are any for your car concerning this.
Edit: Any other complaints coinciding with this one?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-13-2005, 10:11 PM
Thor06's Avatar
Jizzed In My Pants
Things to try:
Replace cat.
I use BP 90% of the time, occasionally I get something else.
Will do that.
Will do that also.
Drink a beer.
I'm going to need more than one! My friends car is spewing white smoke from somewhere under the hood but thats a different thread. Nothing else really, occasionally it will bog in the low RPMs of each gear, but I just thought it wasnt warmed up good. There isnt any black exhaust, any other characteristics of running rich? The gas milage seems pretty normal. Could running rich really smell like rotten eggs? Thanks guys I appreciate it.
Old 10-15-2005, 05:26 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Sulfur smell
I was listening to Car Talk on NPR today and somebody called up today and asked this same question and they said to try changing the brand of gas like SpyderTurbo007 said, and that it is caused by the cat.
