| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
CW question
Okay...before I get all paranoid I just want to ask for some info. Ok first off, I've read through the previous cw posts and read about the ticking noise as the crankshaft grinds down your sensor. Would it only make this noise when the clutch is engaged or would this be a constant sound? The reason I ask this is because my car recently started making a loud noise when the clutch is engaged. My mechanic says it is the throw-out bearing but he is not sure. Also I have read that when you get cw it may be difficult to put it into gears sometimes. My car has issues sometimes going into 1st gear every once in awhile and sometimes it has trouble going into other gears at higher rpms. My clutch also seems to randomly get easier to push in every once in awhile. Also, someone mentioned something about starters and cw...I read and read for an hour or so and never found anything connecting cw and a starter
. But when I want to start my car I have to try for a few seconds or so and just keep turning the key. Everyonce in awhile it magically starts on the first try. But when it doesn't the starter just clicks. I figure this is a result of a starter taking a shit but I figured I would throw it in here too. Thank you for any help you can give me.
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
Re: CW question
Even still I haven't heard of a motor that young having cw.
1991 GSX 2.3 Stroker |
Re: CW question
CHECK THE CRANK ENDPLAY!!!!!!!!!!
Sorry for yelling, but everyone thinks they have crankwalk, so they come in hear all paranoid. Then they spend 15 minutes starting a new thread when they could be laying on the garage floor checking the endplay on the crank. (Rant mode off)
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: CW question
I would but even after reading I'm still not exactly sure I have the tools to do it or even know how to do it... Plus I wrote this thread last night at about 11:30pm and I wasn't about to go out in the garage and check the endplay. BTW the engine was actually rebuilt so its not actually a full new engine. I'll probably end up measuring the endplay anyway since it is really the only real way to put your mind at ease...or put you in a really pissy mood. Thanks everyone.
