Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 10-12-2005, 08:46 PM
92 lude man 92 lude man is offline
Unhappy lude 92 si. no stereo voltage
I HAVE THIS 92 Si prelude, and the previous owner had a big system in it. the problem is, when she took the system out, she took the stock wiring harness for the radio out. I saw it, and NEARLY THREW A FITT! I need help on any stock wiring diagram or something.. pleasse!!!!! HHHEEELLPP!!
Old 11-19-2005, 08:28 AM
Savagetendencies Savagetendencies is offline
Send a message via AIM to Savagetendencies Send a message via Yahoo to Savagetendencies
Re: lude 92 si. no stereo voltage
get a test like and check for a constant voltage make sure your key is off then look for the acc by testing the wires by turning the key on and off and if the light does the same thats acc and then ground but that should be black with silver strips on it and the speakers can be tested with a 9volt battery and two wires plus the wires into the harness spots or the wires if the harness is cut off and listen for the speaker to pop it wont hurt it car stereo shops do this all the time.or you can just pull the speakers out and mark the colors or the wires attached to it and if ur putting in speakers that are not stock make what ever one of the wires you want + and just make sure you mark for your records what one is positive it will save time and hopefully patience.If you have any questions just email me at [email protected] and I will help the best I can I have been fixing stereo stuff for about 10 years now so feel free to ask
Savage
