Old 10-12-2005, 04:47 PM
cutoff's Avatar
cutoff cutoff is offline
tranny code
i have p753 code on my gp gt 97 3.8 my tranny works normally where is the 1-2 Shift Solenoid located ? help me please
-G6 2006 2.4l vvt 170hp
-Grand prix gt 97 3.8l 210 hp
ma page cardomain
ma page monchar.com
Old 10-12-2005, 04:53 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: tranny code
Shift solenoid A circuit electrical problem. Solenoid A is the 1 - 2 upshift solenoid. It not easy to get at because it is located with the valve body which is under the side cover assembly of the driver's side of the transmission. IMO not typically DIY either.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 10-12-2005, 04:57 PM
cutoff's Avatar
should i go to the tranny expert
ma page cardomain
ma page monchar.com
Old 10-12-2005, 05:32 PM
BNaylor's Avatar
Re: tranny code
If you're concerned with the problem then it would probably be wise to take it to a good and reasonable tranny expert. If you are not having any shifting problems, driveability problems or an SES/CEL light hopefully it's a fluke.
I wouldn't totally rely on generic DTC tranny codes such as P0753 but if it's persistent it's valid. Also the shop should have a scanner capable of picking up GM manufacturer specific transmission codes such as P18XX, etc. If it generates a P18XX code that would be cause for real concern. Either way it wouldn't hurt to have an expert look at it. Good luck!
Timeslip 08/12/06
