Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 10-12-2005, 02:56 PM
jellybellyjean jellybellyjean is offline
Question Bogs when you take off
I have a 1994 Jetta GLS III. It was running good and then it started bogging everytime I started to drive it. You know like when you don't shift right and it jerks you around. that is what this feels like but it is not a stick. The coolant flange was busted so we fixed it hoping that was causing it but it didn't help. When it does start doing it really bad it is when the coolant is always halfway up and sometimes the oil light beeps but there is oil in it. Maybe someone has had this problem and can shed some light. Thanks.
Old 10-14-2005, 10:49 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
sounds like a bad maf sensor but the check engine light would be on.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 10-20-2005, 03:06 PM
The check engine light only comes on when I am at a stop and goes off when I start driving again.
Old 10-27-2005, 04:27 PM
kingosiris kingosiris is offline
Re: Bogs when you take off
Check your catalytic converter. It sounds like the same problem I had a while ago.
