Old 10-12-2005, 02:26 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Turbo SOHC!
Hey, I have a 91' SOHC, I heard that they got 8.9 compression ratio and that the motors will be able to handle a decent amount of boost without too many mods...
I have in the works to put a turbo on it, the parts I figure are necessary are below:
turbo manifold & exit flange,
turbo
intake piping,
oil cooler
TT oil housing
boost controller
boost gauge
A/F gauge
fmu (fpr)
oil feed and return lines
I/C and lines
What else will be necessary, and is this a good idea or should I scrap it...
BTW- I'm just looking a small-medium single-turbo to up my hp and gas mileage...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-12-2005, 02:27 PM
Mikelb's Avatar
Re: Turbo SOHC!
oh yeah, BOV and whatnot... the little accessories and noise makers
Old 10-12-2005, 02:32 PM
Mikelb's Avatar
Re: Turbo SOHC!
sry, I also forgot, it'd be a good idea for an EGT gauge, right?
Old 10-12-2005, 02:37 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: Turbo SOHC!
you do know that rippmods.com already makes a pretty nice supercharging kit for the SOHCs right??? Just a thought...
if you really want performance I'd highly suggest just keeping your SOHC as a daily driver and finding a 3/s with a DOHC engine, and than going from there
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 10-12-2005, 02:38 PM
Mikelb's Avatar
Re: Turbo SOHC!
well, true that... but I'm limited on cash, was trying to learn a few things and piece my own together... but yeah, I had already considered rippmods
Old 10-12-2005, 02:40 PM
Mikelb's Avatar
Re: Turbo SOHC!
also, with DOHC you're looking at 10.0 compression, I heard you'd have to build the engine before turboing, especially if you're wanting to boost highrer than say 12 psi
Old 10-12-2005, 02:45 PM
Mikelb's Avatar
Re: Turbo SOHC!
how a/b if I kept the bottom end, and changed the heads over to the DOHC... would that be a bad idea?
Old 10-12-2005, 03:12 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Turbo SOHC!
dohc heads will not bolt to a sohc engine.
you can run tons of boost on a 10:1 engine, its all in the tune and using the right fuel. by tons I mean 30+. the same is probably true of sohc engines
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 10-12-2005, 03:16 PM
Mikelb's Avatar
Re: Turbo SOHC!
sry I heard the DOHC was a bolt-on deal with the SOHC... b/c they are the same block... I heard it was alot less safe to run alot on higher stock compression... I guess that was these people scoffing at my buddy running 10.9:1 on his civic, and then turboing... btw his car was extremely fast (eating 350z's)
Old 10-12-2005, 05:20 PM
r_c_inicial r_c_inicial is offline
Send a message via Yahoo to r_c_inicial
In my mind adding too much power to a front wheele drive is pretty pointless...specially our cars.
1. WAY to heavy.
2. FWD plane out sucks.
3. Way to expensive to Fix if it messes up.
The thing is that there isnt much future. I mean...i LOVE my car. But i know u cant get very far performace wise on a SOHC FWD.
This is just my opinion.
Old 10-12-2005, 05:49 PM
Re: Turbo SOHC!
I dont see 3100 lbs as heavy, but thats just me. Lower compression and FI is safer, but so what.
Old 10-12-2005, 10:17 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Turbo SOHC!
Spawn on 3si has a 98 SOHC 3000gt. With RIPPMODS SDS, their headers and some other mods he put down 256hp the the wheels. This is on a ATX too. A MTX is looking at ~270 with the same setup. There is plenty of potential in the SOHCs as well as about any motor if you do it right.
Old 10-13-2005, 12:55 AM
Re: Turbo SOHC!
Its FWD...potential for me is getting alot. It will take Some serious money to get ur car running 11's like some people do....
Maybe your not trying to run 11's or even 12's but i mean...what about handling?? It will be like a honda civic with balls. But handel like crap.
Old 10-13-2005, 07:13 AM
Mikelb's Avatar
Re: Turbo SOHC!
well, I like the way mine handles, and at 3100 lbs (3076, I think) and a couple of mods, especially rear strut tower bar, and a front sway bar (upgrade)... the car's should handle fine... especially to be running less than 300hp... I am also working with limited funds, so that's why I wish to build the SOHC and do most of it myself.... with the mods I already have, and obtaining parts from some of my sources, as well as the one's listed above... I could have a decent turbo setup on my car for about $600...
Old 10-13-2005, 08:26 AM
Stealthee's Avatar
Re: Re: Turbo SOHC!
The main thing that hurts the SOHC in handling is lack of a rear sway bar. With just ground control coilovers Deathsled on 3si says his SOHC outhandles his VR4. Handling is a non issue.
