Old 10-12-2005, 01:53 PM
r_c_inicial r_c_inicial is offline
Send a message via Yahoo to r_c_inicial
oil pressure gauge...
I have a 91 stealth sohc at. I got the engine swaped from a Diamante and me nor my dad can figure out what to do with the oil pressure gauge. It wont work. The connection from the Diamante is on the left and my stealth had it on the right. Now im in a big elecrical mess...anyone know what to do?
Old 10-12-2005, 02:17 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: oil pressure gauge...
the connection on the engine is relative to the oil pump... so therefore, unless you get an engine that had the oil pump and belts, and whatnot on the same side, you will either have to disregard the sensor and gauge, or extend the wiring... I've never even heard of this being done... but it seems that you could simply splice some wire into the existing wire... and make a connection... IDK... just a suggestion, I'll get back to you when I've had more time to read and think...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-12-2005, 04:56 PM
i think im going to have just disregard it(i know its a horrible idea) and make it a weather temperature gauge...aw.
Old 10-13-2005, 07:07 AM
Mikelb's Avatar
lol, I guess you could do that... but it doesn't seem like extending the length of wire would be too hard...
to test the theory, you could buy a length of wire, strip the ends, and make the two ends touch ( a temporary connection) fire up the car, and see what happens
Old 10-13-2005, 09:24 AM
sLADe781 sLADe781 is offline
If it makes you feel any better, mine doesn't work either and I didn't even do a swap. I tried looking at the lines and sensors but everything was just too short. ;o/
Old 10-13-2005, 10:26 AM
Mikelb's Avatar
I'm gonna be pulling the transmission this weekend and hopefully doing an inspection/rebuild... and I will be inspecting my belts and pumps.. I will do a little fiddling around with my sensor and see what I can tell ya... I'll get back with you early next week...
Old 10-13-2005, 01:21 PM
sounds good dude!
Old 10-13-2005, 03:33 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
yes, extending the wiring will work. I did it on another 3000GT. just get some wire, cut the exsisting wire 4 or 5 inches before the haness/sensor and bingo.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 10-13-2005, 05:26 PM
So wait, your buddy's wires were short too? Hmm....maybe I'll try this then since my wires seem short. What gauge wire did you use?
Old 10-14-2005, 07:18 AM
Mikelb's Avatar
yeah, I was gonna suggest cutting in front of the harness/connector... that way you wouldn't have to fool around with trying to make something else work... haven't had a chance to look at it yet though... let me know how it turns out...
While we're on the subject of the oil pressure gauge... I've recently developed a bearing/pump problem under the hood... I think maybe I need to replace the water pump and oil pump... There are two distinct markings on the pressure gauge... when idling, is it fine for the reading to be lower than that bottom marking (I b/l they mark "normal" pressure range)... b/c mine drops every now and then... and oil burns fast in car (no blow-by that I can tell, no real smoke out exhaust, except when car was running rich (TPS sensor was screwed up) )
