Old 10-12-2005, 12:55 PM
LOUDCRXSi's Avatar
LOUDCRXSi LOUDCRXSi is offline
Send a message via AIM to LOUDCRXSi Send a message via Yahoo to LOUDCRXSi
Need help with Boost
I have a '90 Si with a blown head. I had my friend that works at a performance shop look at it and i've tried different things to determine what was or wasnt wrong with it. Im doin a motor swap and i want to go with a b16. The main reason is i like the redline. While all the B18's and B20's shift at 6500 RPM ill just be hittin peak HP then. But no matter what motor i put in my car im puttin turbo on it. after talkin to friends and doing a little research i dont think the b16 would be good for turbo since the rods are weak and prong to breaking with high amounts of boost.
So now im thinking about keeping my D16 and sleeving the block and getting a ported D16z6 head and intake manifold and putting that on my block i have now. I would like to be able to run 15-18 psi on a T3/T4 hybrid turbo or a Garret T25 if need be.
Which motor would be better for that psi with either turbo?
Old 10-12-2005, 07:00 PM
slowcivichx97 slowcivichx97 is offline
Re: Need help with Boost
if you have the funds i would build a b20 block with a b16 head a b20 has a near perfict bore to stroke ratio and could handle the presure but it would be a heavy heavy swap and exspensive
Old 10-12-2005, 10:01 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
well if you wanting to run 18 lbs your going to need bottom end work done anyways. In my oppinion b16's are good for turbo use because of the short stroke length. If you have the money and know how and throw everything together right a lsvtec or a b20vtec would be a monster.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
Old 10-13-2005, 01:12 AM
arodg25's Avatar
arodg25 arodg25 is offline
there's an article in this months HCI magazine about boosting a b16. They wanted to see how much boost they could throw in a stock b16 before something went wrong. I cant remember what turbo they had but it was a big one. in the first part they made it to 17 psi and 423HP 283 tq then a piston broke where the rings sit. In the second part they replaced the pistons with a set of forged ones, and put the engine back together with the same head bolts! they eventually got it up to 23psi and 507hp 320 tq then ran out of dyno time. The point of the article was that a b16 can take a beating and people who say they have weak rods are just plain wrong. You should go pick it up. It should still be on the shelves.
Old 10-13-2005, 04:18 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
exactly those who said the rods are weak are stupid. they are just as strong as any other b series. and as you probably were told before, dont give us a psi number, give us a hp number so we can accomadte you alittle better to your needs, dont plan on going high hp with that t25, i would recommend the t3/t4
Team Lonely Drivers
Old 10-13-2005, 01:26 PM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
423HP? thats almost if not at least double what i hear the b16 will give u with stock internals but how reliable would that set up be. I dont think u could keep it at 17psi for a daily driver.
The Evil Sleeper
Old 10-13-2005, 01:49 PM
LOUDCRXSi's Avatar
Aight thanks for all your help...I want anywhere from 100-150 hp from the turbo. I want it to spool up quick and mid-to-high range power. which my mind is made up on the T3/T4. As far as the motor..I think a DE16A6 block with a T3/T4 turbo would be unique and deff a sleeper with 15-18 psi which in return (please correct me if im wrong) would give me around 100-150 hp.
Old 10-13-2005, 07:08 PM
arodg25's Avatar
with that turbo i'd expect to see 8-9 hp per psi
Old 10-13-2005, 07:53 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Dont be a jack off, do the numbers insted of just randomly pulling a turbo out of your ass because its popular.
Old 10-14-2005, 01:31 PM
LOUDCRXSi's Avatar
Bitch i did the dam numbers if you werent jackin off to the naked mid-sections of the women on your signature and would take the time to read what ppl are sayin. a post like that shouldnt even been put in here. im tryin to get help about turbo...not someone saying im not doin what i am. i named the turbo and the number and the psi. this is why i stopped postin on AF, stupid ass ppl like you give forums bad reps. and let the admin comin in here and say somin. The silent chamber should kept his mouth silent and shouldnt have been alowed to post. Then i wouldnt of had to get flip when it dont even matter what i say it aint gona change nuttin. Now everyone (except slient i know he/she got somin to say back about this but this is all im goin to say to him) disregard all this and continue on with the topic of this thread.
Old 10-14-2005, 01:57 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Without better rods, that much boost on d16a6 block will go boom!
Edit: or rather, snap....
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 10-14-2005, 02:41 PM
LOUDCRXSi's Avatar
I was looking last night and i found iron ductile sleeves and my mind is made up about getting eagle rods. Im not sure about the pistons tho. My block will be strong and im going to rebuild the head too. i would like to get a ported and polised head along with a ported and polished intake manifold but i havnt been able to find a p&p head and i havnt looked for the intake manifold. i might just buy a d16z6 head and get it p&p'ed myself.
Old 10-14-2005, 03:44 PM
Forunn Daberator
Oh I'm sorry, did I offend you? Would you like a lolly pop? Orally or anally?
Old 10-14-2005, 08:22 PM
first off you dont buy p&p heads, you send your head off to like rs, portflow, etc etc. better to have them do it then do it yourself. if skunk2 sells one for the d series than i would buy that.
eagle rods huh, idk about that. then again if you only want to push 18psi which will probably put you at like 300whp which then will probably only put you in the mid 12s on street tires. up to you
Team Lonely Drivers
Old 10-17-2005, 12:31 PM
LOUDCRXSi's Avatar
So if i rebuild and sleeve the block and rebuild the head will that make a D16 be able to handle 18 psi on a T3/T4 turbo? And how benificial would it be to have a p & p head?
