Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-12-2005, 11:31 AM
T66's Avatar
T66 T66 is offline
Boost on CR
Hi Guys and Girls. I’m going to Turbo a 2 L 16v Mazda motor with a CR of 10:0:1. Would I be able to boost 15psi with sufficient fuelling (4 times 650cc injectors Pump gas) or should I lower the CR? If not, what kind of boost am I looking at on the above mentioned CR?
Old 10-12-2005, 01:52 PM
T66's Avatar
T66 T66 is offline
Re: Boost on CR
Anybody pleeeeeease!
English is not my first Language.
Old 10-12-2005, 02:00 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I would suggest taking the CR down to between 8:1 - 9:1 if this is going to be a street car. With that much boost your tuning will have to be near perfect. You're just playing with fire and 91 octane may just not cut it. Also, if you get a bad batch of fuel at the pump not even the tuning will save you. As soon as you hit full boost you will most like bust you pistons, or worse, and end up with a set of ash trays.
Then again you could bring the boost down on the street. However, 15 PSI at 10:1 on 91 octane equates to ash trays. I would say that you might be alright down towarads 10 PSI.
Old 10-12-2005, 02:11 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
psi means nothing...its all about cfm.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-12-2005, 02:15 PM
T66's Avatar
T66 T66 is offline
Re: Boost on CR
Thank you.
Old 10-12-2005, 03:05 PM
Polygon's Avatar
The Red Baron
Re: Boost on CR
Well of course, but PSI is better understood by most people.
Old 10-12-2005, 09:03 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Boost on CR
No PSI does mean something when it comes to octane/CR selection.
What causes detonation/preignition on boosted cars running lower octane fuel(and higher octane if you run some crazy boost) is intake air temperature. 15psi is still 15psi of heat from enthalpy(s). Efficiency of the turbo will come into play as well. Take the heat created from compressing air to 15psi and divide it by the percentage of efficiency to get actual compressor outlet temperature.
Static and dynamic compression ratio are key to determining what type of fuel you can safely run. Typically you want to stay below 18-19:1 dynamic CR on 93 octane. Note that you will need to run extremely retarded timing which is really dumb IMO. *<20 is just not the way to go. *This is all assuming you have an efficient exhaust system along with an efficient air to air itnercooler. water to air/ water injection setups can def push more on 93 octane. Why? Cooler IATs.
Lower CRs allow for more boost on pump gas due to less compression heat as well. It all revolves around controlling combustion chamber temperature. Fuel burns quicker in a hotter enviroment. But you will notice that on the exact same size engine with two different CR, torque will be damn near the same when it comes time to switch to higher octane fuel. AKA the knock limit. PCP achievable before knock occurs from extreme pressure/temp causing pre-ignition. The fuel begins to burn before spark is applied due to very high pressure/enthalpy(s) temperature byproduct. This is how diesels run.LoL
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
